Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Analog to digital conversion on Aquos?
Does the Sharp Aquos TV have built-in analog to digital capability or do I need to buy a converter box.
  • Anonymous Mar 25, 2014
    tv is hooked to a charter digital box and tv says it is all analog how do I convert it over
  • 4,234 Answers
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
What kind o converter box do i need for the following . Its made by SHARP. OLDER MODEL PRIOR TO DIGITAL CONVERSION
Shawn, If you have cable or satellite the service provider supplies the receiver. If running antenna read the links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Get HD Digital Channels on an Old TV
Who Needs Analog to Digital Converter Box
http://www.walmart.com/c/kp/digital-tv-converter-boxes
Consumer Reports magazine March 2009
May 12, 2016 | Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
Do I need a digital converter box for sharp 13VT N100
Yes you will need on because you are receiving a analog signal and will not decode the digital signal without one.Hoe this answers you question.
May 18, 2009 | Sharp 13VT-N100 Combo
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Dec 20, 2008 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
2,262 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
