Question about Intermec EasyCoder 4400 Thermal Printer
Printing labels
Printer will only print 60 labels at a time
  • 5 more comments
  • sarahq993 Sep 25, 2008
    Printer just stop at 60 labels, no matter how many I request.
    The printer is connect directly to the computer
  • John Michael Swan May 11, 2010
    Are you using the serial or parallel interface?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What software is it using?
  • Tim Babcock
    How is this printer configured to print?  Is is connected to a computer or is it a stand alone on a network?
  • Tim Babcock
    What happens after printing the 60th label?
  • Tim Babcock
    What happens after the 60th label is printed?
    Scholar:
  • 45 Answers
Bubbabear64: Oops. Sorry if I interefered by requesting info after yours.
Sarahq993:
I could be wrong, but I think you are connected through a (null modem) serial cable without proper flow control, so the printer fills up with an error condition after 60 labels. If you're usinf this caqble, it would be screwed into a nine pin connector on your PC and would be screwed into a 25 pin connector on the lower part of the back of the printer. If I'm wrong, please let me know and I'll try again.
There are two banks of dip switches on the back of the printer, with a chart showing their meaning (baud, data bits, stop bits, parity). The switches are only read when the printer powers up, so cycle the power if you change them.
The settings on the PC must match these settings.
Right click on the printer name, select "Properties", "Ports", (probably) "Com1", "Configure Port". Set the same baud, data bits, stop bits and parity as the printer, and also turn on Xon/Xoff flow control.
Please let me know if this works, or if I'm wrong.
Label_Guy
Posted on Oct 01, 2008
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
I have a kl-60-l label maker.
Here is the link to CASIO KL-60 Manual
Check the troubleshooting section in the end, and also the "Resetting the Memory" section.
Aug 09, 2009 | Casio EZ Label Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
I have a casio kl-60 EZ-LABEL Printer my batt was low tried to print and labeler said ERR. Changed Batteries still said ERR. Please help lost manual. Tried to find manual online. would be nice to have.
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_60_E.pdf
Aug 14, 2008 | Casio Computers & Internet
Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Nov 22, 2007 | Zebra Z4Mplus Label Printer
Intermec EasyCoder 4400 Thermal Printer Logo
201 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
