Mitsubishi rear projection 50 inch tv picture is distorted and has ghost images
1. Pull the Video and Audio cables; then (if you are to obtain a small steel brush) very gently polish both ends of the cables.
2. Replace your current Video cable.
3. Verify Frequency setting on the TV.
Posted on Sep 23, 2008
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Tv has a ghost image in red
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 50H72 50" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
