Problem with MSPVIEW
Can't open .tif file from Microsoft document Imagaing.
Error message: MDI has encountered a problem and needs to close.
  • STEVE LEE Sep 23, 2008
  • 1,250 Answers
When the file has been saved on tiff format the wrong compression and set byte order ibm pc
Posted on Sep 29, 2008
Thanks for info.
Is it possible to make word repair document?
When you restart a Microsoft Office program after a power failure or similar problem, the program automatically opens any recovered files.
If for some reason the recovery file didn't open, you can open it yourself.
1. On the Standard toolbar, click Open .
2. On the Show pop-up menu, click All Documents.
3. Locate the folder that contains your recovery files.
Each recovery file is named "AutoRecover save of file name."
4. Open the recovery file.
5. Click Save .
6. In the Save As box, enter the name of the existing document.
7. When you see a message asking whether you want to replace the existing document, click Yes.
Any recovery files that haven't been saved are deleted when you quit WorTips
• If you can't open the recovery file, you can try to recover the text from the damaged file.
• To find out or change where your recovery files are stored, click Preferences on the Word menu, and then click File Locations.
Otherwise apply Word Repair Toolbox
Tool has a lot of different tricks, know more at:-
Feb 08, 2015 | Microsoft Office Word 2007 Full Version...
Are there instructions available, for someone not that PC literate, to send an e-mail with a Winfax Pro document as an attachment?
If you know how to send an email, the rest is easy.. Firstly, save your winfax document into your "my documents" folder and make sure you remember the file name. Setup your email as you want it then click on the "add attachment" button at the top of the screen (this depends on which email system you are using but most attachments can be added from the new email screen). In hotmail and windows live, use the attach button and select file. In outlook and outlook express, use the attach button on the top toolbar. Click on file and a dialog box will open asking for the file you wish to attach. Use the box to navigate to your my documents folder and then select the winfax file you saved earlier. If the file is not showing, click on the file type box and select all files. once you have found your winfax file, select it and click on "ok" or "attach". Wait for the system to upload your file and then click on "send".. You're done !!!
Nov 09, 2009 | Symantec WinFax Pro for PC
Scanner wont scan
Be sure that you have the latest scanner drivers from HP, for your system and OS. Often an easy workaround is to use Microsoft Office Suite document imaging.
The ms program can be found in the tools folder of the suite...Plus is that is almost always works on most any scanner, the minus side is that it creates only a .tif or a .mdi file. To read those, you need to set your DEFAULT program settings to call the Microsoft MSP viewer, typically located C:\Program Files\Common Files\Microsoft shared\MODI\11.0.
HP has been working on solutions to this issue. Further, HP has LIVE, free support available online, try connect to chat.
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
I cannot print my documents even if there is Microsoft Office Document Imaging?
open Microsoft Office Document Imaging then opened the Tools menu, then
Options. In the Options window, select the "Other" tab and clicked on the "Reset" button under Default Program.
Then, close Microsoft Office Document Imaging and open windows explorer, navigated to an "*.MDI" file, right clicked it and chose "open with" "choose a program" then browse to the Microsoft Office Document Imaging executable found in the Office folder (don't remember the exact location) and select that executable to open *.MDI files and check the box "always use this program to open this file type".
Now, finally, the "File" menu in Microsoft Office Document Imaging will work
May 12, 2009 | Microsoft Office Professional 2007 Full...
Olympus Master 2 Software gets Microsoft Error Message
This is solution for you:
Apr 19, 2009 | Computers & Internet
Lost right click capabilites.
You may experience any of the following symptoms:
  • When you right-click a file, Windows Explorer may quit unexpectedly, or you may receive an "Access Violation" error message, or you may receive the following error message: Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. When you view the details of the error, you find an error signature similar to the following: AppName AppVer ModName ModVer Offset
    Explorer.exe 6.0.2800.1221 Ntdll.dll 5.1.2600.1217 00054084
  • After you install Windows 2000 Service Pack4 (SP4) or the 823980 security patch (MS03-026) documented in MicrosoftKnowledge Base article 823980, you may not be able to open .max or .drffiles in the following products:
    • Discreet 3DS Max versions 2.x, 3.x, 4.x or 5.x
    • Autodesk Architectural Desktop 2004
    • Autodesk Building Systems 2004
    • Autodesk VIZ 4
    • Autodesk 3D Studio VIZ R3 or R3
Mar 25, 2009 | Microsoft Windows XP Home Edition
I need to scan my documents as a pdf in order for the receipients to be able to open. This scanner is only giving me two choices...tif and mdi. Is there any way to scan items as a pdf?
No. You need to scan then convert the .tif into a .pdf. There are many good converters around, some of them freeware or costing around $30 or as shareware. You could do worse than starting your search at the url below.
Good Luck.
Dec 02, 2008 | Computers & Internet
Scanning on sharp AR-168D copier, printer, scanner
Check your default program for .tif files by going into my computer and finding a tif file. Move the mouse over to the file and press the right mouse button and select properties. Check the opens with icon to see which program it is using. If it isn't set for Microsoft Word, press the change with button and select Microsoft Word. Press the Ok button.
Your tif files should open with Word.
Sep 25, 2008 | Office Equipment & Supplies
Scanned copy cannot be saved
Try to downlaod the software from
May 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
