Question about Mr. Coffee MRCTB Coffee Maker
MRCTB Parts Hi, I need to buy a resevoir cover for this model coffee pot, not only is the lid missing but the plastic cover around the resevoir is broken at the hinge, any suggestions on where to get this?
  • Anonymous Oct 22, 2008
    Need new resevoir cover for a Mr Coffee Commercial Coffee Brewer,Model #MRCTB
High limit switch is bad. Where can I get a replacement?
Posted on Aug 24, 2011
I need a lid for my basket in my General Electric pot belly perculator. Model P410B. Is there one that comes with it?
It came with one. Start looking around thrift stores and other venues that sell old items. Recent ebay listing for the complete unit for your reference: http://www.ebay.ca/itm/261742163021 (wow!)
Mar 23, 2015 | Coffee Makers & Espresso Machines
Where can i find a plastic lid for rival creock pot #3654/1
Go to the Rical crock pot web site and there should be a place to buy replacement lids. Or Google for one, with your " make, model and replacement lid."
Mar 05, 2015 | Rival Crock Pots & Slow Cookers
Hamilton Beach Model 49756T does not filter water from resevoir pump into filter.
at only 2 months chances of it being calcified are slim, the fact that the coffee is dry is the catch. some place when you close the lid there may be a little trip switch, a tiny tab like the one on your washer causes your washer to start when you close lid, same concept but way small. THat's not it? There are some coffee pots that the position you place the handle will create a varence in the lids ability to properly come in contact with the filter cup, a pressure censor so to speak. Then i would guess there is a blockage in the transfer line, and last a pot that just killed itself after 2 months. (it's still under warranty :))
Mar 28, 2012 | Coffee Makers & Espresso Machines
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
http://www.starbucks.com/customer-service
Good luck, and hope this helps.
Nov 09, 2010 | Microwave Ovens
THE MR. COFFEE COMMERCIAL COFFEE BREWER MODEL MRCTB. IT DOESN'T HAVE ANY LABEL. MY QUESTION IS JUST NEED TO KNOW IF I CAN USE THIS IN 110 V OR 220 V. SINCE IT IS COMMERCIAL.
Hope you can help. Water runs though pot but the water is not hot whatsoever. Heating element burned out?
Commercial Brewer 8543
Apr 20, 2010 | Bloomfield 8543 Coffee Maker
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Pumping more water out than what i put in
This coffee maker uses a resevoir tank system - the water you pour in pushes out water that is already heated - the water you pour in won't actually be used for that pot of coffee! For that reason you should only use full pitchers when filling. You may need to cycle through 2 or 3 fillings before the input matches the output once more. The capacity of the resevoir is about 3 pitchers; you can brew 2 pots in a row before the machine needs a break to bring the resevoir back up to temperature.
Nov 12, 2008 | Bunn VPR Coffee Maker
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Replacement Coffee pot
I have the same problem with my coffee maker, but I purchased mine in Walgreens more than a year. In Walgreens it has a different name (Signature Classics), but I'm sure its exaclty the same as the Haier HDC10LBS. I called and they do have replacements. The model#XQ698LT ITEM#W14A7123 and the Customer Service Phone#1 800 645 3869. The cost should be around $10 with Shipping and handling
Sep 18, 2007 | Haier HDC10LBS Stainless Steel 10-Cup...
Mr. Coffee MRCTB Coffee Maker Logo
467 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
