You have a pressure sensor problem and will need to replace it. Pressure Sensor This will correct the problem you have with your unit. To access it, your will need to removed the 3 screws on the back of the unit to the top cover only, slide the cover back to the rear of the unit to remove. Locate the part and replace it, it should be mounted toward the front control but I have seen models where it was toward the back. It is on the top though and accessible.
Thanks and good luck Gere
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
