Question about Epson Stylus Photo R200 InkJet Printer
How is 4" x 6" paper loaded?
I've tried to load smaller paper into the printer, but only get a partial print of a part of the full size image. When I reduce the image size in Photoshop and use a sheet of 8.5 x 11 I get the size I want, but if I use the smaller paper, I get about one fourth of a full size-image. This is a problem of both the computer (iMac, 2002) and the R200 printer.
So, whass'p widdat?
  • 184 Answers
There are settings that should allow you to specify the page size usually in the printer program that is installed on your computer as well as if you were using your printer as a stand alone device ,it will not be a problem with your Mac or printer but perhaps the instruction menu not been user friendly , I suggest you look at your printer settings in trouble shooting under paper loading etc or paper size as even the very cheap printers allow for smaller paper sizes even envelopes .You might try the print preview which should let make changes if need be .
Posted on Aug 07, 2017
SOURCE: R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Posted on Feb 15, 2008
SOURCE: Paper won't load. Media loaded incorrectly.
Okay.. 1st off I'm probably going to the jumped on for this... But.. I fix and/or make them work printers, computers and all sorts of electronic gear. For a living... Yes .. the manufacturer will tell you not to use alcohol to clean the rollers. but it does work. Windex (ammonia) will clean the heads at times. I also use Scotch brite pads to clean the pickup rollers. We get them in about 8x10 inch pads.
I will spay some alcohol on the end where the pick up roller is. Place the pad in normal paper tray. Most printers have a cam shaped one on the right, left or in the middle. That gets the paper moving. The pad is way to thick to actually move and will cause a jam indication on the printer. But what happens is the roller will slip on the pad and clean itself. Pretend you cleared the jam a couple of times and the printer will try to pick up the 'paper' and jam again. A couple of these and the pick up roller (cam shaped) will usually be good to go. The other option (the best) is to buy a new pickup roller for the printer. But cleaning will work for the short term. What happens on most printers is the roller gets very smooth from normal use and then won't pick up the paper for the rest of the trip through the printer. I have used a piece of fine grade sand paper, but you have to hold it so it won't go through the printer and it makes a gritty mess... Once I orderd a 'printer cleaner' from HP and all it was, was a couple of pieces of scotch brite glued to a fancy holder to match the spacing of the rollers. That's when I started using sheets of the stuff. Just pretend they are a piece of printer paper. In the worst case I have used belt dressing and then alcohol to clean most of it off. Alcohol has a tendency to soften the rubber on the pickup roller. That's why the company says don't use it. But you can by rubber rejuvenator that is mainly alcohol.. Go figure.........
Posted on Mar 21, 2009
  • 511 Answers
SOURCE: Epson Stylus Photo R200 will not accept DVD tray
Have you select the media in printer setup?
Posted on Jun 14, 2009
SOURCE: printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
Posted on Sep 11, 2009
  • 51 Answers
SOURCE: Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Posted on Sep 26, 2009
Mirror image properties
I think your image size is too large. when you command your printer to print the image. choose the paper size on which you want to print it.operating system will automatically set the image size to the paper size
Dec 06, 2013 | HP Officejet H470 InkJet Printer
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
are you asking how to load different size paper? or how to make your printer recognize what type of paper to use now that you are ready to print?
Normally specialty paper can be form fed in the back of printer (depending on what type you have). If you have no problem loading the paper, your program that you've designed your project in should control the print size. Try going to the advance options on the program you're using when you ask it to print. Also, use the print preview to make sure it has the right size paper.
Jul 31, 2011 | HP Office Equipment & Supplies
I'm trying to print custom size papers. I've selected the mph on the printer with the settings for paper type. I've selected manual on the computer, with the settings for paper type and size....
What sort of printer are you using?
The printer may have a feed switch, which allows you to choose the feed location. Sometimes this physical button on the printer will override any software settings.
May 06, 2011 | Office Equipment & Supplies
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. ...
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
In the program being used for printing, click File , and then click Print .
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
Apr 23, 2011 | HP PhotoSmart C4280 Laser Printer
I have a Lexmark C522 When I print to it...the image that should be a full page prints really small on half of the page. How can I make it print what I send it?
this problem would indicate that the printer thinks the paper is smaller than it is. check the paper size settings on the drawer if the settings are right the replace the paper size pcb
Dec 03, 2009 | Lexmark C522n Laser Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Error message unable to print
1.The printer is asking you to manualy load the right size paper.
source tray possibly tray 1
2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages. are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
Jan 02, 2009 | HP LaserJet 2550L Printer
Can i print the image smaller?
  1. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  2. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again.
  3. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  4. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value.
  5. In 'Scaling', specify the percentage. You can select from 20% to 400%.
  6. Click 'OK'.
Mar 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
