By network54
Here's the deal ive got a 2 year old RCA 27" Entertainment series and I was watching a movie and heard a pop and then the picture was gone. Still had sound but no picture, if I turn it off then back on the picture comes back.Sometimes for minutes sometimes hours, or it doesnt do it again. Any ideas?
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 04, 2008
I have this model tv and I am experiencing similar issues. My screen rolls, goes in and out black and white and is sometimes gone altogether. No issues with sound at all. I have not done anything as I would not know what to do. Please advise. Thank you
Solution #1
posted on May 30, 2006
To me, it sounds like a bad solder joint in the flyback area or the vertical output section. When it is operating correctly, can you induce the failure by whacking the top or side? That is not a "definitive" test, but can indicate a bad wiring or solder connection.
You can inspect all joints and connections looking for a bad one, but it often takes a trained eye to really know what one looks like. Sometimes they are very obvious with a distinctive crack around the solder connection. Other times, the bad connection is inside the joint and not visible to the naked eye.
If you are handy with a hot iron, you might be able to find & fix this yourself.
Right now, your TV is telling you it needs service. Take it in and have it repaired before some major part blows due to surging and arcing across/through a bad joint.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA 27V530T 27" TV
Email this problem
Email this problem
Can you Help with these Standard Televisions problems?
RCA 27V530T 27" TV
RCA 27V530T Powers up and plays...
I just bought an RCA 27V530T... Answer This...
Repair Service
Find Standard TV Repairman Near You:
Find Parts
