Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Plantronic 510 not charging properly
Fairly new 510 is not charging properly--if you leave it on charger too long will it damage the battery, don't find information regarding overtime on charger
  • Anonymous Nov 14, 2008
    mine is over 1 yr and is doing the same thing
    smart charger seems to have lost its brain.
    It wasn't like the battery was going bad it just stopped working.
    I haven't used it that much and it was working just fine
    put it away and when I took it out it was dead.
    has been on charger 3 days and is still blinking red.
  • ruggb Nov 14, 2008
    Sergeant:
  • 243 Answers
No it has a smart charge system which does not allow for that to happen.
Thanks,
Nate
Posted on Sep 23, 2008
My Bluetooth needs a charger ,what charger is best to use
Any bluetooth car or home adapter will do, but the specified amp or milliamps (power strength) adapter would be best. My Plantronics M155 came with the 180mA adapter which is very light; quarter amp.
Dec 06, 2013 | Plantronics 510 Voyager Headset - PLN-510...
My headset will not hold the charge very long - is there a fix for this - is there a battery somewhere on this unit that can be replaced?
Unfortunately, the Plantronics Voyager 510 Bluetooth headset does not have a replaceable battery, it is "hard wired". However the 510 headset does have a one year warranty, so Plantronics will replace it within the warranty period. If it's out of warranty, you can buy a replacement if you'd like or buy the newer version which is the Plantronics Voyager Pro+, which is just a newer, slimmer model and it also has newer technology (for the same cost). Here are the links below.
Here is the link to the Plantronics 510 replacement headset.
Here is the link to the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
Aug 25, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Won't take a charge
This has a non replaceable battery, you can always purchase a new headset. 84321-01 this is just the headset.
Good luck from Headsets Direct -0800-914-7996.
Aug 14, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
Can i leave my bluetooth (plantronics 360) plugged into the charger all the time when I am not using it?
Yes. Modern chargers stop when the battery is full and only do a "trickle" charge to keep it full.
The only real concern would be a power surge which can damage any electronic device that is plugged in at the time.
Mar 25, 2011 | Cell Phones
When you press earpiece to pickup call the phone lift not working and a red light blinks on front left on desk top charging station .It worked fine yesturday - I come in today and it doesn't work. there...
This could be several problems, I am going to give you the one that I believe is the answer. It sounds like it may need to be subscribed again. First here is your user guide:
Plantronics Voyager 510 User's Guide
If that doesn't work, it may be that your headset is bad. If it is you can replace that with this headset:
Plantronics Voyager 510 Replacement Headset
Mar 01, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
My psp battery loses power "quickly" and charges very slow....
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
308 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
