there are three ways to fix Failed to get proc address for get logical : update your windows xp to service pack 3 update your window to windows 7 or windows 8 install skype version 6.6.0.106 Reference: pakwing
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
The drivers from Logitech help and can be downloaded from thier support site. The software they have lets you use profiles for all the games you play with the joystick, that way you don't have to constantly calibrate it for each game. The windows drivers will work the joystick....just have to go to control panel, game controllers and enable and calibrate the joystick.
