Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you fix error F5?
The washer starts to fill with water and after about 3-4 mins it shuts off and error F5 will flash before washing cycle begins. I am able to start the load again from that point, but won' t clear.
  • 5,911 Answers
"F5" is a temperature sensor error. The following link explains how to diagnose and correct:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
The first thing to try, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches. If the error code reappears, then you know you have a legitimate error. In many cases, the small connector that plugs into the heat sensor either becomes corroded, or comes loose. Make sure you troubleshoot the washer while it is UNPLUGGED.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 29, 2009
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
What does a steady flashing wash light mean?
pump all the water out and stop the wash cycle your on
open the door
then disconnect the mains supply for 10-15 mins
then turn it back on and hope the software fixes itself
otherwise there is an issue its detecting
like the door interlock is being detected as bad.,..
if the motor isnt running perhaps the motor brushes need replaced and this is the cause of the flashing wash light
and motor not running
i would check out the brushes have atleat 3/4 " on them
if not replace them
Dec 20, 2014 | Hotpoint WD440 Aquarius Washer/Dryer Combo
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
My washer starts lets shuts down with a code of f5
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
•Check the Water Temperature Sensor, Heating Element and Element Relay
•Check connections to the Sensor, Heating Element and Relay
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
343 people viewed this question
Sal De
fordexpert
Robert Rankin
