Question about HP Compaq Trio64 V+ (240109001) Motherboard
Monitor hp d2817a ultra vga 12180
HP D2817A VGA monitor ULTRA VGA 1280
how to adjust to gray scale and intensity of brightness?
AND WHERE TO BUY.
My computer have not VGA and drives mail me my drive i have big problem
Posted on Sep 24, 2008
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Apple multi scan 20 display. Screen works fine but green is predominant. How and where do I adjust the green intensity?
This can be adjusted by the RGB settings on the menu (monitor setting menu button on the monitor), Brightness color contrast also helps.
That is providing that its the settings thats causing your problem. In my experience the VGA cable sometimes shorts out producing that green hue. You may need to shake the cable a bait to see if it clears up or causes weird iterations. Once this happens it means the cable is shorting. It could be a broken solder to a broken wire. Replacing the vga cable and resoldering the connectors inside the monitor (where the cable jack connects to the main board) fix's the problem.
Feb 25, 2010 | Apple Multiple Scan 20 20" CRT Monitor
Cannot adjust the brightness and the contrast
Ali Bhai
Thank you for your query
To rule out vga card issue, please can you try plugging the monitor into another PC, if it works in there then it is your vga card at fault and this will need to be replaced.
I f however the moniotr does not improve then im afraid your monitor is faulty, when the monitors go dim it is genrally the inverters that are faulty
Please book the monitor in for repair/replacement
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank you again
Feb 15, 2010 | HP L1940T 19" LCD Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Sep 29, 2009 | HP w17e Monitor
W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
Which should i go for in best performance in all tasks such as graphics and wireless and over all performance ?? pavilion DV6-1205 core2duo T6500 (2.13GHz/800MHz/2M cash)intel 45PM Chipset,HP1.3MPcam...
Graphics are always going to be the hangup with ratings.
A large processor is grate but will display alot of heat. Heat and time kills.
Which ever you purchase, I would get an extended warranty.
Check the pros and cons on the internet first.
Sep 24, 2009 | HP Pavilion dv6000z Notebook
X2gen MV19 monitor: can only get VGA resolution
unscrew the monitor check behind the line transformer you will see two buttons for adjustment use them to increase your resolution manually
pls make sure the monitor is shut down for abt 15-30 minutes before you attempt opening it to avoid electric shock
Mar 17, 2008 | Computers & Internet
Dell Trinitron Ultra Scan Monitors
Yes as long as your monitors have the standard 15 pin Mini D-sub connector (which they do) then you should have no problems viewing a composite input through your converters.
Jan 04, 2008 | Dell Ultra Scan 17TX - 17" SVGA Color...
HP Compaq Trio64 V+ (240109001) Motherboard Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
