Question about Canon imageRUNNER C3200 Copier
Canon ir3530 i have ir3530 but i need install print nic so what ido
  • 38 Answers
As far as I know this machine comes fitted with a network adapter already and all that needs to be done is for you to purchase the license (this comes as part of the PCL or PS Print Kit) to enable the printing feature. I know with some models an additional memory DIMM also needs to be installed. I'm not sure if this is one of those models, but in the event that it is, the DIMM is also supplied with the print kit and it is accompanied by a complete set of installation instructions
Posted on Sep 24, 2008
My copier canon ir3530 occured error code E-000024-0001.How to solve this code?
E024 developing assembly connector disconnection fault..this is what it is saying on the internet.
Nov 19, 2016 | Canon Office Equipment & Supplies
Ir 3530
please cleen your scanner home position sencor
Jun 30, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Haw to find the all night power suply in ir3530
There is No such power supply called "all night power supply". Have you tried to adjust the display contrast on the control panel????/
Jan 13, 2013 | Canon IMAGERUNNER 3530 Copier
Im looking for service manual for canon ir2870 copier
Here: http://www.smpcshop.com/Canon-iR2230-iR2270-iR2870-iR3530-iR3570-iR4570-Service-Manual.html
Dec 20, 2010 | Canon Office Equipment & Supplies
Ip address IR2800
You need to tell copier the IP, gateway and subnet. If you have DHCP set Ip on auto.
Jan 27, 2010 | Sharp AL-1642CS Copier
Connected ir3300 to network. Can ping static ip address. the PS3 print driver install detects the printer on the network. Printing fails - print times out every time. Tried installing printer on Server...
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
Aug 17, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
Printer keeps pausing itself!!
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Aug 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Printing connected ethnet set ip address wil not print
Go into Additional Finctions, select Network Settings, input IP Address, or select DCHP. Connect to PC or network. Download relevant printer driver. Switch photocopier on/off. Everything should work ok. Let me know?
Nov 30, 2007 | Canon imageRUNNER 2200
Canon imageRUNNER C3200 Copier Logo
215 people viewed this question
old marine
old marine
