Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Ice Maker Model No. GSS25QGTA WW---Our ice maker fills the pan, then spits out cubes(during the night--big bang). I find no adjustments to slow down the making of ice. Any thoghts would be appreciated. Bette & Bob Prouty--e-m--bbprouty@att.net
Put less water into the ice tray.
Posted on Sep 23, 2008
Is there an adjustment for the fill level on the whirlpool ice maker? Its to full. Cubes are all linked together.
You are exactly on the right track...
but without a MODEL NUMBER one could only take a wild STAB in the be-wilderness.
You older generation twist tray... and heasted sweep tray
had TWO (2) adjusting screws immediately under the front cover
of the ICE-MAKER head...
Neither took much of a twist to SIGNIFICANTLY affect fill level... or change the TRIGGER temperature
resulting in SLOW DELIVERY... or FAST DELIVERY of hollow (partially frozen (under-done)) ice-cubes....
A really GREAT IDEA would be to get the OWNERS MANUAL... &
(ready)... ((drum-roll))....
READ IT.
I'm just saying...
ELSE ... disclose which of the millions of Whirlpool
ice-makers you might be referring to.... Mod. number!!!
Me...
Carnac the Magnificent
Jan 19, 2017 | Whirlpool Refrigerators
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
(REFRIGERATER or ICEMAKER)...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Water leaking than freezing on floor of lower draw under ice maker in subzero 700tf freezer
If cubes are very large the ice maker may be overfilling and need the fill adjusted to allow less water into the maker. Otherwise check the fill tube (runs from the back wall to ice maker) for loose connections or cracked tubing. (In this instance the cubes would be smaller than usual.) If neither of these is the source, then look up to the highest point of ice (water flows downhill) for the origin. Suspect a stopped up defrost drain. Thaw and clear ice, then clear drain tube (DO NOT use a wire for this) with warm water and a turkey baster. Once water is flowing through tube and into drain pan under the unit the problem should be solved.
Dec 05, 2014 | Refrigerators
Icemaker makes lil ice cubes now could this mean the line is clogged?
Would not expect you to ask this question but yes you are right cajunboudoin, an obstructed water line by either a defective water control valve, water filter beyond its useful life or a crimped water supply line will cause the ice cubes to be small during drop of ice cubes into ice bin. Fact is with Whirlpool the water valve is set to remain open filling ice maker for around 7 seconds. If water is moving slow filling the time will be to slow for the flow, If anyone has a good question you do but I would always want everyone to provide their model number, Click Here=> Whirlpool Ice Maker Troubleshooting Thanks Sea Breeze
May 06, 2012 | Maytag Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
Replaced water valve but still will not supply water to the ice maker
Because your model has the mechanical type ice maker it is likely the ice makers thermostat is the most likely problem. Test ice maker by filling with tap water. Once the water freezes te thermostat tells the ice maker first to warm the bottom just long enough to cause the cubes to loosen in their slots and next th rake begins to cycle the cubes up and out of the ice maker and into the storage and auger pan. If the water just freezes and the ice maker does not cycle the you know the water control valve is new. The thermostat is what tells the cycle to begin. depending on the age of the ice maker just changing the defrost thermostat would be the best choice. I will display photos and links in a few moments, Sea Breeze
Mar 04, 2010 | Whirlpool GD2SHGX Refrigerator
Ice maker makes ice cubes, but the doesn't dispense ice cubes.
If you could observe exactly where the water is dripping from it would help but...If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Aug 19, 2009 | Refrigerators
How do you stop ice dripping
There is a water valve ( usually behind fridge in-line with tubing for water ), the valve is activated and releases water to fill cube tray. Does yours continue to fill or is it just overfilling a little too much and then stopping? You could try doing a search for schematics or diagrams for your make/model on Google for more info on how to adjust if it can be adjusted. Good Luck. If you are only getting a little bit of water in the ice pan and its just an annoyance, you could look for a plastic grid material that you could cut to fit into bottom of pan to keep ice from sitting in water. Then just empty water every so often.
Jul 02, 2008 | Refrigerators
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
