Acer extensa 5602z e-lock management password i have forgot it I'm looking to override it somehow
5 Suggested Answers
  • 13433 Answers
SOURCE: acer elock
You don't need to pay acer the 100usd to get the password removed,
one thing you can try first, is to disable the elock service from
start -> run -> type in services.msc
look for elock service right click properties startup type disabled and stop the service, on some elocks this is enought to stop it from working. but it debends I can fix this and I have done it many times now..
Posted on Dec 02, 2008
  • 145 Answers
SOURCE: Forgot normal password and supervisor password for eData Security
The only thing you can do is to reinstall to os at this time or try to fine the password
Posted on Dec 12, 2008
taran_2005
  • 10515 Answers
SOURCE: I forgot my password for
Download the sofware and enjoy :)
http://acer-elock-management.software.informer.com/
Thanks.
Posted on Dec 28, 2008
  • 7 Answers
SOURCE: Bios password on acer extensa 4620
ok on all desktops there is a jumper on the motherboard conecting 2 out of three pins and on the motherboard it says psswd. power off and unplug it then remove the door on the back where the ram goes ill bet thats where ull find it. take the jumper off and put it on the other pins. boot it up and password should be dissabled go int bios and make sure. u can leave it like this or turn off and replace the jumper. hope this helps.
P.S. if the jumper isnot by the ram check behind any other doors the laptop might have
Posted on Jan 24, 2009
pagebor
  • 2785 Answers
SOURCE: rest bios Password acer extensa 5620z
plz check the link
Posted on Jun 22, 2009
How can I reset password
Bypassing windows 7 password acer aspire one - Acer - Laptop Tech ...
www.tomsguide.com/.../60319-35-bypassing-windows-password-acer-as...
Aug 18, 2011 - 12 posts - ‎10 authors
I haven't used it in months and can't remember what password I used ... To log on to acomputer as the administrator to reset a password, when ... Forgot my acer recovery management password
Mar 14, 2013
How to reset acer aspire one hardrive password
Oct 15, 2012
Acer notebook locked forgot admin password
Aug 16, 2012
I forgot my password to unlock my acer computer
Nov 23, 2011
More results from www.tomsguide.com
Dec 18, 2015 | Acer Computers & Internet
FORGOTTEN PASSWORD
acer lock management?
Jun 10, 2008 | Computers & Internet
How do i override my computer password
Look for HiRen's Boot CD. It has a utility where you can boot and reset/blank out the administrator's password and log in.
Aug 10, 2014 | E-Machines Computers & Internet
Hello! I live in Norway an have a problem with my computer - it says that acer e-lock i activated and i cannot use my dvd/cd station. I am not very good in computer "thing" so you have to explain very...
The Acer Elock is used to protect your computer from any external device or access like flash drive, any external media device, optical disc DVD etc.
To make the DVD CD station active you need to go to acer elock interface and enter the password which you first entered on the computer while doing acer elock system.
http://acer-elock-management.software.informer.com/screenshot/54477/
This link can help you as it has a step by step method and screenshots also.
The only disadvantage of this Acer Elock system is if you forgot the password you need to go to Acer Custoer Center and get it fixed
Please check if the above things will help you and let me know.
Regards
Nov 26, 2009 | Computers & Internet
Acer extensa sm bus controller not loaded on device manager
please specify the model number of your acer extensa,however, you can try downloading and installing this
becaue I believe that the driver that you are missing is the chipset or the card reader driver found here
May 03, 2009 | Computers & Internet
I HAVE ACER EXTENSA 5210 LAPTOP & THE PRBOBELM OF LAPTOP IS BIOS PASSWORD HOW CAN I REMOVE IT
I have Acer Extensa 5210 laptop,the problem is some keys have locked up e.i j,k,l,m,u,i,0,p& 0 when i press j Instead i get one how can i inlock thesekeys
Jan 10, 2009 | Computers & Internet
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
Unlocking my elock on my acer extensa 4220 laptop
http://global.acer.com/products/et/notebooks.htm
as per the Acer website you press the Empowering Key (looks like a stylised "e")
then follow the menus to unlock you will need your password
if you have problem with this you need to email support on http://www.acersupport.com/html/email.cfm
hope this helps
Oct 17, 2008 | Computers & Internet
Forgotten passwords and cant re install windows because of setup utility password on my acer extensa 5220
You need to remove the 3v CMOS battery from your laptop
Passwords are generally managed by this battery.
Jun 02, 2008 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
148 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
