Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Problem for Hitachi EC12 Portable Electric 2hp Air Compressor, Oil...
My EC12 builds up pressure, but then releases all but about 10 psi.
By gharrant on Sep 23, 2008
The machine builds pressure fine, but when it reaches max (125 psi), it releases all but about 10 psi.  I initially thought that the spring loaded pressure relief valve had went bad, but the air comes out of the small hole in the brass fitting below and to the side of the relief valve.  I am not sure if this is a pressure sensor or not, but it has a small air hose from the tank the pressure switch.  Any ideas?
Same Problem
Nov 14, 2008
-   My compressor is an Eaton that is just like the Hitachi, but it has oil in the compressor. My compressor (a portable) starts pumping when I turn it on. It goes up to 120 lbs and then at the point it is to shut off, it does. The air then starts escaping from the compressor switch and purges the tank down to 70 lbs; I believe that this is through the unloader which is built into the pressure switch. The compressor tries start up again, but fails and repeats this action until I shut the system down by pulling the plug because if I try to depress the on and off switch it lets more air out of the tanks. The pressure switch was replaced with a new one, but this did absolutely no good, it keeps doing the same thing. -   fc143
Nov 12, 2008
-   same-   Guest
Oct 25, 2008
-   Compressor runs normally and pressurized the two tanks.  When the pressure reaches the cutoff psi, the motor shuts down.  However, immediately after, a small hole in a brass fitting behind the pressure switch and fitted to a rubber hosing, starts to leak air at high velocity.  Pressure drops and quickly reaches the minimum set point.  At this point, the motor reengages and starts to re-charge the tanks.  This pattern continues and there seems to be no end.  -   Guest
Best Solution
posted on Nov 22, 2008
Very Helpful)
twodogs2
Rank: Apprentice
Rating: 100%, 2 votes
Bruno2
This was a great find, been having this problem for a while, but your suggestion worked. Thanks so much.
twodogs2
Was this helpful?
Yes
No
Solution #2
posted on Nov 14, 2008
Very Helpful)
bruno2
Rank: Apprentice
Rating: 100%, 14 votes
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #3
posted on Oct 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ACORDING TO THE MANUFACTURES SPECS ON THIS MODEL COMPRESSOR IT HAS AN OIL SPLASH SYSTEM AND I KEEP SEEING IT REFERED AS A CHEAP OILESS COMPRESSOR...IM TRYING TO DECIDE WHAT ONE TO BUY BUT NOBODY SEEMS TO KNOW WHATS WHAT AND NOW NOT SURE IF I WANT ONE OF THESE...
Solution #4
posted on Oct 07, 2008
Helpful)
teddux
Rank: Guru
Rating: 88%, 339 votes
Yes, this is normal.
It is a safety valve.
1.)
Someone turned up the max pressure adjustment past the 125 psi limit.
Readjust back down to about 110 psi.
2.)
If it releases all the pressure after it kicks off (after building max pressure), then this is quite a common symptom of cheap oil-less compressors.
From your description you have a cheap oil-less compressor.
Was this helpful?
Yes
No
Solution #5
posted on Nov 15, 2008
Somewhat Helpful)
fc143
Rank: Apprentice
Rating: 70%, 4 votes
bruno2 you are a winner. I did what you said and it worked!!!!!!!!!!!!!!!!! Thanks pal, you are a winner. The Apprentice knocks out the big guys. teddux if your car ever needs repairs know that it is a cheap piece of junk and you should have purchased a _______.
Was this helpful?
Yes
No
Solution #6
posted on Mar 12, 2009
Not Rated)
yankeeblade
Rank: Apprentice
Rating: 0%, 0 votes
Bruno2
Thanks for the solution! Worked like a charm!
Was this helpful?
Yes
No
Popular Solutions for Hitachi EC12 Portable Electric
Questions and Unsolved Problems for Hitachi EC12 Portable Electric
Do you recommend Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated?
Answer
Answer
Certain nails cause my Akuzuki floor nailer to jam. Others (same type, brand, and size) work just... (More)
Answer
vokera linea 24 keeps flashing 01 and 03 and works every now and again
Answer
runs up to 32psi then blows motor braker
Answer
Model rp 40001 stuck on 40 psi. how can I recalibrate?
Describe your Air Compressors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Compressor Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
