Question about Philips Magnavox Learning Universal Remote
Masterplug tvrc4n 4 in 1 remote control/sanyo
Hello everybody,i've spent the last couple of days trying to input codes into this remote,could someone please,please give me the codes for a sanyo tv,if it helps the tv model number is ce28WN4,any help would be greatly appreciated,cheers.
  • Anonymous Mar 21, 2014
    hi friends,i want know how to enter service menu for sanyo tv wiht a model # ce28wn4b
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): Masterplug tvrc4n 4 in 1 remote control/sanyo - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 23, 2008
I need the TV code for Sanyo CBP2180-1 for use with Masterplug Universal Remote control
Sanyo Codes:
1224
1225
1233
1275
1330
1338
1339
1340
1341
1342
1343
1213
1062
1063
1064
1065
1074
1082
1088
1089
1109
1145
1205
1213
Feb 19, 2009 | GE JASRM24912 Remote Control
Lost a book
Samsung Codes for Masterplug 4 in1 TVRC4N remote:
1050
1074
1089
1102
1103
1109
1113
1176
1221
1223
1224
1225
1239
1281
1286
1287
1288
1289
1290
1291
1292
1293
1294
1295
1337
1369
1381
1385
1388
1389
1390
1393
1402
1408
1410
Oct 24, 2008 | Philips Magnavox Learning Universal Remote
Masterplug 4 in 1 remote control codes for Panasonic TV
Panasonic Codes:
1056
1107
1108
1147
1148
1149
1150
1151
1152
1199
1206
1321
Aug 22, 2008 | Philips Magnavox Learning Universal Remote
Masterplug tvr c4n remote(universal)
Try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jul 13, 2008 | Philips Magnavox Learning Universal Remote
Universal remote TVRC4N missing code
If you read your instruction booklet you will find a section for code unknown, or try thomson codes Ferguson have been made by Thomson for 15 years plus.
May 31, 2008 | Televison & Video
Have lost instructions for masterplug 4 in 1 remote tvrc4n
hi, the method to perform an auto scan.
Generally you can press the function button you want to programme, then hold SETUP down till the red led flashes twice. Then tap in 991. Now press the power button, followed by the function button that you are trying to set, repeatedly. When your piece of equipment turns off, press and hold the function button again. You should be all set.
May 04, 2008 | Televison & Video
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
Samsung vcr 0278 or 0455 as above. Angela.x.
Feb 22, 2008 | Philips Magnavox Learning Universal Remote
Programming Codes
hello cant you help me
i have a dvd recorder Model is DMTECH DVD-400RW
i have note code
if you have it cant you send it to me ond this mail
04273105@telia.com
Mvh Micke
Jan 01, 2008 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
878 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
