Kenmore 90 Series Washer
My washer wouldn't spin the water out. After looking at it I determined I needed a new lid switch assembly which I purchased. I can't seem to figure out how to remove the top control panel in order to reach where the old plug needs to be remove and new part plugged in. Can you help me with this?
  • drb1 Sep 26, 2008
    I can't get the sides off, I'm afraid of breaking something. Do you just force them off?
  • 958 Answers
This came from my research of the web...
Lid switch broke off (plastic housing broke in half at the screws). This definitely gets easier after doing it just once. Took me a while to figure out I needed to pop off the plastic caps on the sides of the top control panel, to expose the two screws that others mention. Remove the two screws, lay the control panel forward exposing the two metal clips on top holding the cabinet in place. Unhook the clips, voila. The plastic connector of the replacement switch didn't exactly match the old one so I cut and splice (wire nuts and tape). Cleaned everything well while I had it all apart. If I ever have to do this again, it should take a fraction of the time.
im sure its the same as yours.
tnx 4 using fixya,
drcool
Posted on Sep 23, 2008
  • francis rivero Sep 26, 2008
    if i'm not mistaken, these plastic covers slides up. the clips of the covers are at the front. slowly pry them up wards.
    good luck,
    drcool
Kenmore washer series 80 will aitiate but not spin with load
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Jul 07, 2009 | Kenmore 22422 Top Load Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Washer leaks after installing new lid switch
Glad this was taken care of. I'm just closing out some old tickets here.
May 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
