Question about Toastmaster Breadmaker's Hearth 1193 Bread Maker
The wing nut on the bottom of the bread pan has worn and no longer turns the kneading blade on the toastmast breadmaker's hearth model 1143S
Flip in over, that works for me.
Posted on Jan 03, 2009
  • Tea1776 Jan 03, 2009
    Details: Take off the C-clamp holding the wing nut and turn it upside down and replace the clamp. this will help it extend lower to reach the motor better. Not sure if it is a permanent fix but has worked for me.
Breadmaker's hearth 1193
Turn the little impeller blade on the bottom of the pan with your fingers so they don't contact the impellers in the bottom of the oven. Think of it like this: You don't want both to be aligned like this:
+ + You want them to be aligned like this: + x so there is clearance for both ++ alignment won't allow your pan to pop in...
Nov 24, 2013 | Salton Kitchen Appliances - Others
Need manual
Hi Linda: Am a bit confused by the subject line and your question.
The Use and Care Guide for the Toastmaster 1143S - 1193 Breadmaker's Hearth Breadmaker & Cook's Oven can be found here:
http://kitchen.manualsonline.com/manuals/mfg/toastmaster/1193.html?idRes=635320
Please clarify if you are looking for a manual for a Hamilton Beach product and the model number.
Thank you for using FixYa!
Oct 20, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
I have toastmaster model 1193..as it mixes the dough it makes a grinding sound- the shaft and the mixing blade are worn. how /where can I get replacement parts for this. We LOVE the machine and hate to get...
You can often find them on ebay at reasonable prices. I have an older model toastmaster that is almost new if you are interested let me know. Sometimes you can find the pan and paddle assemblies up for sale and/or auction there also.
Dec 08, 2010 | Toastmaster Breadmaker's Hearth 1193 Bread...
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
Lost my manuel /part that kneads the bread model 1190
E-mail me and I will send the PDF file
k.holcomb@mchsi.com
or contact, Michelle Macklin
Customer Service Agent- Team Leader
mmacklin@fox-international.com
Dec 07, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Missing part for a bread machine
sometimes they're sold used on Amazon- search there under the model name and number
Feb 07, 2008 | Toastmaster 1183N Bread Maker
Kitchen Appliances - Others Logo
96 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
