Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Took it apart to clean it now i have unscrewed and a spring has come out that makes the door to the filter open and close. oopps
  • brandtk27 Nov 24, 2008
    I was cleaning my Cuisinart Grind & Brew and took out a screw now I can't get the spring back in. Please help
  • 2,071 Answers
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused only little produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
Posted on Sep 23, 2008
  • LORETO LACARON
    LORETO LACARON Sep 29, 2008
    what happen to the spring?
Bakers pride problems
I am betting that a lift assist spring has come unattached. You will have to take it apart to find where it did and how to reattach.
Aug 31, 2014 | Ovens
Rival deep fryer door does not spring open nor does it stay open
Yes you need to make sure the springs didnt fly off when you opened the panel, otherwise look for the mounting post that the spring should hook into
Aug 21, 2012 | Rival Kitchen Appliances - Others
How do I fit a new door gasket to a Hoover DT999 dishwasher (the short horizontal seal at the bottom of the door, not the longer one which wraps around the inside of the body of the machine)?
Well I just did this (ew!)
basically it just pulls out of a slot downwards (when doors open) but there's not much space so I took out a few screws to free the door up a bit.
So - sitting with the machine in front of you and door open down towards you:
I took out the two machine screws that hold the door on to the spring/hinge mechanism. Those are the two on the side of the door near to the hinge/bottom.
I also took out 3 of the screws that screw the inside metal bit of the door on to the plastic fron of the door.
You'll notice that the springs then force the inside and outside of the door apart and you've got some free space to pull the bottom seal out of the metal door. Then clean everything and squeeze the new seal in.
You're probably not going to be able to thread it in from one end.
When you're putting those two machine screws back in you'll probably need to do the top screw (nearest you when door open) with the door almost closed so that the spring is most relaxed and will let you line up the two holes.
Hope that helps
Dec 16, 2010 | Hoover 24 in. DT999 Free-Standing...
I have unscrewed all the screws and can't get bottom off.
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
Sears leaf blower will not start normally
Your problem is that the jet valve is being partially blocked. unscrew the carb. label the intake gas line and then the outflow, so you wont get mixed up when reattaching. unscrew both sides of the carb, on one side of the carb will be the pump diaphram and the other side will be another diaphram. you will see the metering valve which I have termed the "jet valve" unscrew the screw that holds it together with a phillips screwdriver. Be careful!!!, there is a tiny spring that pops out and is easily lost. Use a carb spray and clean all ports and holes. spray the jet and spring. On reassembling the spring be careful. Use a 150+ reading glasses if you are unable to see well. Carefully place the spring in the indented spot, place the jet between the grooves of the tiny leaver making sure that there is a part that must fit on the spring. If you fit it upside down then the machine will die off at full throttle. slip in the pin. Press down the spring and screw down the phillips screw. reassemble the carb exactly as you took it apart. It is important to remember or document. The first time i did it I made a tiny scratch between parts so i knew how to align them properly. After reassembly try starting. Rev at full throttle, if problem persists check the filter inside the gas tank it may be clogged. If it is replace. If problem is still there, open the carb again where the check valve is located, place a flat steel ruler over the valve assembly and press down the end with the jet. This will level the jet. If problem persist get a carb kit. Your carb will either be a zama or walbro.
Oct 31, 2009 | Garden
My wife was washing some throw rugs in the HE5t and one of them fell apart in the wash. Clogged up the filter and will not drain. Door is locked so I can't get inside to clean filter and washer. How do I...
hello, You should remove the lower panel at the front of the machine, behind there you will find what looks like a gas cap from a car right next to the pump, unscrew the cap making sure you have plenty of towels handy and remove the filter...empty the water out and clean the filter...re-install the filter trap and you should now be able to open the door. Don't forget to unplug the machine before servicing. Hope this helps, thanks for using fixya..good luck . Mike
Aug 06, 2009 | Washing Machines
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
I was trying to clean my cuisinart DGB-600 coffee maker. I unscrewed asmall hex screw under the black piece that slides out and a spring popped out. This spring helps keep the filter basket door button...
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
Sep 23, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Spring
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jul 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
94 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
