Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Windows configuration zero
I have fully installed my Belkin 802.11g adapter onto my windows xp pc, however it is telling me that i need to adjust the windows configuration zero settings to connect to my sky router, what should i do?
    Problem Solver:
  • 13 Answers
To get to the Windows Zero Configuration settings in Windows XP:
Right click on My Computer>>Manage>>Double click on Services & Applications>>Applications.
Scroll down and right click on Windows Zero Configuration>>Properties. Make sure your start up type is Automatic and that the Service Status is Started. I hope this helps!
Posted on Sep 25, 2008
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 22, 2013 | Belkin F5D9050 Wireless G Plus MIMO USB...
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
I have F5D7234-4V1 with insight internet connection and i have win-xp laptop , ERROR MESSAGE - (windows cannot configured wireless ) tell me what to do - But unable to start WZC on my computer
If you want to use Windows Wireless Zero Configuration to manage the wireless network, you will need to have Windows XP with service pack 2 as a minimum.
With Windows XP and SP2, you will need a Microsoft update for WPA2 that can be obtained from:
http://support.microsoft.com/kb/893357/en-us
After installation you will need to use the Windows Zero Config wireless configuration in the control panel to configure the adapter. WPA2 should now be available and work correctly.
Windows XP with Service Pack 3 and Windows Vista offer support for WPA2 without additional updates.
Nov 04, 2010 | Belkin F5D7234-4 Router
I have a belkin surf/share usb adapter f7d2102 got a good signal i hit connect windows searches it cannot connect i have tryed for a d------ nweek it has to be in the configured something need unchecked...
Hi i got your issue .....
Try with the following steps ....
I hope that when you scan and connect for the network ..you will get the message as "windows cannot configure any wireless networks"
This means that there is a conflict between xp utility and belkin utility but this can be resolved by the following steps
Step 1: Click on the "start " and then go to "run"
Step 2: On "run" type - "services.msc" and then hit "ok"
Step 3: Now a new window pops up ....there u please search for "wireless zero configuration " and double click on it
Step 4: You will get a " wireless zero configuration -properties window"
Step 5: IN that window check that the start type should be "automatic" and the service status should be "started "
Step 6: Then click ok and close the screen
Step 7: Then click on start -control panel-network connections- wireless network connections (make a right click) and
you will find properties and at the top you will have the option"wireless"
Step 8: On that screen you will have the check box as "use windows to configure to my wireless networks "
Step 9: That check box has to be checked then click "ok"
Step 10: Try scan and connect -you will have the network -you can connect to it
Hopefully this will work ....
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks.....
With regards ......
Priya ,,,,,
Oct 03, 2010 | Belkin Surf Share Wireless USB Adapters...
Windows xp identifies Belkin f5d5010 Network card as a generic ethernet controller and is unable to find a driver to install properly this adapter
If you find that you can not connect to a wireless base station (such as Apple's Airport) because of issues with the configuration software provided by your wireless adapter's manufacturer. You may wish to uninstall that software (but keep the drivers) and use XP's native support for wireless networking.
In order to do this you may need to turn on XP's wireless zero configuration.
Start -> Run
Type in services.msc
zwc001.gif Click the OK button, which will bring up the following dialogue.
zwc002.gif You may want to maximise the screen. Scroll down to Wireless Zero Configuration and select it.
zwc003.gif You now have the option to Start the service.
You also need to change the Startup Type from Manual to Automatic
Action -> Properties
zwc004.gif Click OK.
You can now use XP to manage your wireless connection.
May 12, 2010 | Belkin (F5D5010) (F5D5010AU) Network...
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin G+ Mimo USB adapter help!!
Make sure it is not in the windows START UP folder so that it will not use the belkin configuration. Check that software tool's prefrences by selecting 'use windows wireless configuration' as well, from within the windows wireless configuration tool icon on the systemtray, you have that option to 'always use windows'
To enter the services to set the wireless zero configuration cick on the start menu then on RUN and type services.msc and click ok - now look for the wireless zero configuration and doubleclick on it. Change the setting to AUTOMATIC and if it is not already started, start this and click OK
In case you are unsure where the windows start up folder is found, click on the start menu then on ALL PROGRAMS and you should see START UP. You will find that wireless utility device which should be removed (right click and delete)
Mar 27, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
G+ mimo Notebook Card
She probably has both the Mimo Utility and the Windows XP Wireless Configuration Utility running at the same time.. Try disabling the Windows Configuration Utility and see if she can connect now..
Start > Run > Services.msc (OK)
Disable Windows Zero Wireless Configuration
Here is a visual explanation I found:
http://www.ifelix.co.uk/tech/2000.html
Dec 04, 2007 | Belkin High-Speed Mode Wireless G Notebook...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
