Canon Copier blank pages
Suddenly getting blank pages. No error lights. Plenty of toner. Yes, original is in proper side down. Yes drum is OK. any thoughts?
  • John Bulcroft Sep 23, 2008
    OK
    Where do I find the primary wire and seperation wires? I don't have a service manual.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Blank copies come from the primary wire a) either not having contact b) broken
also double check the Seperation wires
Posted on Sep 23, 2008
  • CheckitRight
    CheckitRight Sep 23, 2008
    Primary is the unit above the drum
    Seperation is directly below it
Colour Laser Printer Problem
Don't use refurbished drum. Proceed with new.
Nov 21, 2013 | Canon LBP5200
Copies come out blank.
several possibility of problem are:
- empty toner (you must check it)
- moist paper (solution = the copies which come out blank return to paper case, to use again. it is mean to use not moist paper)
- lifetime of the drum is over.
Jun 21, 2011 | Canon PC-1060 Black and White Copier
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
Canon NP4050 putting out blank pages
The NP 4050 has been known for given blank copies... Is the developing unit locked in place... There is a Grey or blue lever inside the front door to the right... It is under the toner hopper. It's been along time... I believe the lever should be clicked to the right and up. Also there is a locking screw that holds it in place, Most times that screw is missing and the unit falls away from the drum unit and you get blank copies and the front door will close.. Good Luck
May 01, 2010 | Office Equipment & Supplies
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
Canon NP7130 copier
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Nov 12, 2007 | Canon NP 7130 Black and White Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
343 people viewed this question
jasbo
jasbo
