Question about Xerox Phaser 8200 Laser Printer
Fixing the lamps of xerox phaser
Hi
can you tell me how to change the lamps of the printer.
you can send the description to emmer27@versatel.nl
thnxx
marco
    President:
  • 2,072 Answers
Are you asking about a Phaser printer. Like a Phaser 8200, 860 ?? Just want to be clear on what info I am sending. But I would be glad to send you the directions.
Posted on Sep 26, 2008
  • Rick Kasper Sep 26, 2008
    Ok you should have an E-mail containing the directions for replacing the lamps on a phaser printer.
    If you have a different printer let me know.
Xerox Phaser 8400 Front Cover Open
Yes, there is an OPEN/CLOSE sensor that is sending wrong "status" information to the printer.
Jun 01, 2010 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8200 fault code 15.004.45:30386
That is a drum heater fault code. The drum heaters are 2 ,,, 150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps. Let me know if you want me to send you info how to change them.
rak458@aol.com
Mar 09, 2010 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8550 having color quality issue
If you are using third party ink sticks contact the manufacture and they will, if you use enough of thier product, send you a new print head and send out a tech to change it. Media Science is the most likely source of third party ink.
You can also switch to Xerox ink sticks and the colors will be correct after several purges to get rid of the old ink.
Harry
Sep 29, 2009 | Xerox Phaser 8560DN Laser Printer
Error Code: 15.004.45:113654
That code means the drum heaters are not working.
The good news is, yes you can fix it yourself.
The drum heaters are 2, 150 watt halogen lamps. One or both of them have blown out. If you want drop me an E-mail at rak458@aol.com
I will send you instructions how to replace them.
It would take 1 to 1 1/2 hours if you have never done it before. Lowes, Home Depot or any place that sells halogen lamps would have them.
I however, do highly recommend, if you can find them. Sylvania halogen lamps rated for 130 volts and have vibration protection. They cost slightly more, but well worth it. Besides even if you get those, you have less than $15 in the repair.
Let me know, I will send you the info. That's all your problem is.
May 06, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 8200N hangs on warmup
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Mar 07, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
67 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
