Question about JVC AV-32260 32" TV
JVC problems Mike, I seem to be having the exact problem described - your response is below - my question is roughly how much would a repair like this cost. My tv is 2 ys old and cost about $400 when new, is it worth spending the money to fix it or should I get a new one? I'm not sure of the model number, its a 32" JVC iArt CRT Thanks, Jay It is not a fuse, since if the fuse was bad, the power LED would not light at all. I have seen that symptom many times and I usually find 2 problems which cause this. On some sets, one of the larger caps in the power supply's secondary side degrades just enough that the set will not start. On other sets, I usually find that the small transistor that turns the relay on has shorted out, and the 11 volt zener diode next to it is usually shorted too. The transistor is a very small surface mount transistor, so the set should be serviced by a qualified tech experienced in JVC sets.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: tv does not power up
You answered on your own. (lol)If its suppose to be a standby 12 volt supply then whats the top voltage to be there?? 12 VOLTS!!! The value your looking for is a 12 to 13 volts 1 watt zener diode.. Im thinking your a handi man trying or attemting a repair?? please remember the HI voltage saftey issues, as these sets hold alot of HI voltage even after they are unplugged for a while. Good luck
Posted on Jun 28, 2006
SOURCE: horizontal output transistor
You can Swap them if they are of the same rating, must check the wattage. cause the width problem & the power transistor become over heat. you can also use both of them in parallel, if they are ok. your tv live longer.....
HAVE A NICE DAY...
Posted on Feb 12, 2008
  • 2326 Answers
SOURCE: Mitsubishi cs40507 blown zener diode
It should be at the back cover, just where the model number is. If you have the TV open, it may also be found inside, maybe on or around the tuner area.
Posted on Feb 22, 2008
gopakumarg43
  • 74858 Answers
SOURCE: my jvc iart 32'' tv picture has shrunked 4'' either sides , looks like a small pillow , plz help
Check its main power regulator section. The output voltage from the SMPS is low.
Posted on Sep 29, 2012
Testimonial: "ok i will check the ps and give u a shout , ty u 4 ur advice"
My JVC Everio Hard Disk camcorder is stuck in zoom. We have tried everything and cannot seem to get it to unzoom.
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 18, 2011 | JVC Everio GZ-MG130 Camcorder
We have a JVC AV-32FA44 television. It is almost 8 years old. The tv worked fine. Turned it off. A short time later turned it back on and there is sound but no picture--just a black screen. My brother had...
There seems to be issues with the soldering on it getting old and loose, also there are some common parts that burn out or go bad over time. I am not sure if you want to spend the money or are going to be able to find someone to fix it.
Dec 11, 2017 | JVC AV-32FA44 32" TV
Describe your JVC GR-D240 Mini DV Digital Camcorder Problem Hi my problem is when I try to record the lcd screen is showing no picture for me to view - but if I put in an already recorded tape - the...
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 11, 2011 | JVC GR-D240 Mini DV Digital Camcorder
Just purchased second hand JVC model GR-DF470AA cant seem to view anything via the camera or the veiw finder
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 02, 2010 | JVC GR-D370 Mini DV Digital Camcorder
2007 Land Cruiser stalls to idle and non responsive to gas pedal
Had exact same problem after driving 120 miles in Florida heat. After 30 minutes started but ran rough for a day and now seem fine. Thought at first fuel filter or dirty gas. Going to replace filter anyway. Is this a common problem?
Jul 09, 2010 | 2007 Toyota Land Cruiser
Hello my name is Mike, I have a GE
The link below describes disassembly of the dryer you have . You will notice that the manual is for Westinghouse and Frigidaire. GE must have had some made for them also. Circuit diagrams and control panel appearance may not be exactly the same but disassembly will be.
The disassembly section begins at page 61.
DBL333EB3WW Service
Sep 30, 2009 | Dryers
Jvc rx 318 receiver
The problem you describe is common to JVC amps. This control has a motor mounted on the back of the circuit card that drives the volume control up or down using the remote control for this system. The looseness of the volume control cannot be repaired. The shaft has separated from the potentiometer. I don't know if JVC has this part any longer but it has to be replaced as a unit (volume control card).
Nov 07, 2007 | JVC RX-318 Receiver
JVC AV-32260 32" TV Logo
139 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
