Question about Panasonic Workio DP-2500E Copier
Workio DP 2500
On the screen a spanner has appeared in the top left corner and the copier is not functioning. What does this symbol mean and what do we have to do to rectify it...?
    New Friend:
I keep geting diffrent answer , i remember doing something on the screen.
Posted on Jan 30, 2013
My printer have paper jam and on top of the screen it say ( Check printer E04-01) Is there any solution to this.? Printer model # DP-2500.
TThanks
Posted on Dec 02, 2008
    Sergeant:
  • 284 Answers
Means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Posted on Oct 31, 2008
Can't change the screen to English
Just follow this procedure...
  1. Press Tools, the symbol in the bottom right corner of a spanner.
  2. Press Settings, the symbol in the top left corner of a spanner.
  3. Press Language, the symbol of lips
You'll can see 3 bars one for text language, one for voice language and one for keyboard layout.
Press each one in turn and select english as the language.
Good luck.
Apr 08, 2011 | Garmin nuvi 205W GPS Receiver
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
Call for P/m Fuser Web
just press
function+org size A3+3
choose f5
c70 non
c73 non
have fun
Dec 15, 2008 | Panasonic Workio DP-3010 Printer
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
For copier panasonic workio dp-4530
you mean all departments codes?
if you are the person incharge of copier on your company,
1) press function, gen settings, depart. mode,
2) input the 4 digit key operator code, the search for department mode again.
3) press the department code on the left side of the touch panel then you can erase each department code.
i hope hope this is helpful
Jul 17, 2008 | Panasonic Workio DP-4530 Copier
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
Hi again
Hi BBNJ try this 1. To select the Service Mode The service mode is selected when ?FUNCTION?, ?ORIGINAL SIZE? and ?3? keys are sequentially pressed, then F1 will appear in the display. 2.press number 5 to get f5 on the screen then press green start button 3.you should see `c00` on the screen key in 70 the screen should read c70 press green start again key in 0 and then green start button this should switch off the spanner 4 2. To exit the Service Mode The service mode is reset when the ?FUNCTION? and ?CLEAR? keys are pressed simultaneously kind regards Dr Bob1
Mar 29, 2007 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-2500E Copier Logo
234 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
