I have a HP Deskjet 9800. It' doesn't want to print 11x17 size paper. It will feed an 11x17 sheet but nothing printed on it, after that the paper feed light blinks, and eventually the printing task bar shows 'Printing-Error'. Vista 32-bit OS
I can't tell you for sure which thing I tried and worked, but I noticed the USB cable looked slightly damaged, so I switched it out. But the thing that I actually think did it was that I was using the A3 size paper because there was no 11x17 paper size with the exception of a banner 11x17, which I didn't try becuase I wasn't creating a banner.
But none the less, that did it.
Posted on Sep 26, 2008
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
I want to use 11x14 paper on my dj1280 but it is not in the menu. neither is there a provision for user-defined paper sizes. what to do?
The 1280 isn't compatible with 11x14 paper. You can either use legal size (8.5x14) or ledger size (11x17), but you can't customize it to use 11x14.
The best solution would be to print onto 11x17 paper and then cut it to 11x14.
Jan 14, 2010 | HP DeskJet 1280 InkJet Printer
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
bobh@mvps.org (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Jun 05, 2009 | HP Business InkJet 2800 Printer
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Paper Jam when there is no paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 21, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
264 people viewed this question
jasbo
jasbo
