Question about Epson Stylus DX6050 All-In-One InkJet Printer
E-04 paper jam
Hi there
My name is emmie and my epson dx6050 printer has suddenly started flashing up with an E-04 paper jam. There does not seem to be any paper trapped any where, i have checked. Any advice would be greatly recieved.
Many Thanks
Emmie
  • 1 more comment
  • helecra Sep 24, 2008
    HELP E4 paper jam PLEEEEEASE help!!!!!
  • dan2862 Nov 24, 2008
    same as emma... i've just tried to get my printer working aftrer several months, and the same problem is recurring... E-04. Can't see any paper jammed anywhere though.
  • Anonymous Dec 08, 2008
    Same thing for me. Sarah
Hi, my printer did the same and following the instruction of turning it of and clearing any jam didn't work. In the end I forced a sheet of paper into the printer intake at the rear of the machine and turned it off. The printer then took the sheet in about a third of the way. When I switched the printer on the sheet was then drawn through and out the front as if it were printed on. I think the printer has some sensors which must detect a sheet passing through them for it to reset. Hope this works.
Posted on Mar 23, 2009
I had the same problem of DX6050 paperjam, luckily I was able to find a little bit of paper stuck under the white plastic bouncy part in the paper input feed. There's not a lot of access so I think it's likely there's just a scrap of paper stuck and hidden in the mechanism. Not sure how you'd remove it without taking the printer apart.
Posted on Apr 23, 2009
I've got error code E90, what can i do?
To correct my E-90 error I opened the lid and saw that there was a torn piece of paper under the carriage which jammed the carriage so it could not move. Two minutes later, after I moved the carriage by hand and removed the paper jam, I powered off and back on and I'm back in operation. Thanks to all before me who suggested it might be user fixable.
And Thanks.
Mar 29, 2010 | Epson Stylus DX6050 All-In-One InkJet...
Error code E-04
I would check that there is nothing inside the paper feed system. The smallest piece of paper might cause a jam. Take the inks out and give the printer a good shake then put inks in and try again.
IHave you had a jam recently and pulled the paper out to clear it?
Jan 10, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Error e-04
Looks like you have a printer that is not available for sale in USA. But you could probably start here:
http://support.epson.net/
Hope this helps.
Dec 18, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson DX6050: Feeder pulls the paper in from just one side
There might be small peice of paper stuck in the paper path. use a flashlight to see if there are any obstructions in the machine. use a thick peice of card stock to maybe push the paper out.
Aug 03, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Feeder / roller problem on epson dx6050
Call Epson tech support, they will walk you through it.
Jun 29, 2009 | Epson Stylus DX6050 All-In-One InkJet...
E-04 problem. doesn't appear to be any paper jammed. Fix?
PUSH FRESH SHEET A4 FOR ROLLERS TO GRASP.IT CLEARED MY BLOCKAGE. TRY SLIGHTLY CRINCLING THE PAPER TO ROUGHEN IT UP IT MAY PUSH BLOCKED PAPER OUT
Feb 27, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I Have An Epson Stylus DX6000 Printer Problem
Yes I had the same problem. Well we looked online and found the answer. Pick up the printer and shake upside down (Carefully) and an EPSON badge fell out. On reboot of the printer the error E-04 solved. Printing happily. Well it worked for us.
Nov 07, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Epson Stylus DX6050 All-In-One InkJet Printer Logo
389 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
