Question about Belkin N1 Vision Router
Trying to connect a Mybook 1Tb network drive to N1 Vision
I'm trying to connect a new 1TB WD Mybook network drive to my network via the router ports on an N1 Vision Router, but although I can see all the other PC's (3) and access the internet ok, I can't find the Mybook on the network. I also can't get Mionet to run, which from what I have read might not be such a bad thing.
I have connected the drive driect to my pc's ethernet port and manged to access it that way, but only from my machine and I want it availble when my machine is shutdown, ie via the router hub.
    Scholar:
  • 47 Answers
Hi! I have an N1 Vision with similar problems. I have done some research and found that we are not alone with this issue! Two solutions are possible: 1) If yours is version 1 (1000) of the machine, Belkin recommends that it be swapped out for version 2, which apparently has firmware/hardware changes that fix this (unverified; it would seem to me that this would require a whole new DHCP approach) and 2) I've found that if you go through the process of unplugging the device for 2 minutes, replugging it and then refreshing the DHCP table, after between 1 and 5 iterations, the device should appear. I'd also advise you to shut down (for troubleshooting) the software firewall in the router (you'll still have the NAT firewall), that might eliminate a problem/conflict somewhere in your network!
Good luck and let me know if this helps!
Bob
Posted on Oct 07, 2008
Cannot get 1TB WD MyBook to work on NetGear N600 Router
this link is quite illuminative
click here please
seems that drive configuration needs to be done when connected to pc first then after it's recognized, added to network router
May 21, 2012 | Western Digital Computers & Internet
I have a WD MyBook Essential 1TB external hard drive installed with my Mac OSX 10.5.8. The drive is only being used for Time Machine and my iTunes backup. The drive will randomly unmount itself and I get...
I would suspect that either the USB cable or port is the problem. Change the USB port (On the Mac or on the WD MyBook (I don't know if it has more than one USB port) that the cable is connected to and see if that improves the situation, if it still happens change the USB cable. Hope this helps.
Mar 22, 2011 | Western Digital My Book Essential 1TB...
My wd 1tb mybook no longer powers up-I have archived versions of these files but i would prefer to get the data off this drive
Is it still under warranty?
Possibilities:
* try connecting to a different USB port on your computer
* try connecting to a USB port on a different computer
* try a different USB cable between the computer and the MyBook
* disassemble the casing, and remove the disk-drive, and connect it as a "slave" drive in some desktop computer, to see if the files on the disk-drive are intact
If all else fails, search online for "professional data recovery service" -- a company that will repair the MyBook just long enough to copy all your files onto a new disk-drive. Of course, this is _expensive_.
Note that Western Digital has a Customer Loyalty Program -- knowing the serial-number on your disk-drive, you can buy a new MyBook from their web-site, at a good discount.
Apr 23, 2010 | Western Digital My Book Essential 1TB...
WD Mybook - can't access "Public" folder!
Windows firewall would be local workstation only - is your company deploying a hardware firewall solution. The ports would need to be opened to allow that traffic in. Like on your router you needed to open UDP ports for the mybook to get out. You need to so the same to allow traffic to get to the device.
I'm assuming the device is plugged directly into a router. You should consider on the router creating a DMZ for the worldbook to reside in. Of course you need to understand what that means for your data. If it is not sensitive data than a router DMZ provides enough security, if it is senstive data I would not advise that. Too many evil doers on the internet.
Let me know
Jan 29, 2010 | Computers & Internet
WD mybook 1TB is gone from the network
Have you tried different cables or a different port on your router. Is there any way to get into the Hard Drive by connecting it directly to a PC and checking the network settings or anything..? If not, then you may have to connect it directly to a PC and share it to your other PC's.
Sep 15, 2009 | Western Digital My Book World Edition 1TB...
WD & Seagate ext HDD not getting connected toBelkins N+ router
hmmm..
Start > Run > devmgmt.msc
Check if there are some errors shown under USB devices..
Also try changing the USB ports...
Use the ports in back of ur CPU.
Also check
Start > run > diskmgmt.msc to see if your device / Hard disk is listed there.
Assign a drive letter to the drive if no letter like e:, f: etc is assigned to it.
Aug 09, 2009 | Belkin N1 Vision Router
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Belkin N+ modem router (F5D8635) not recognizing Maxtor 1TB HD
I could not find the F5D8635 model but here is the Firmware update page for the N1 Vision Router.
Try updating your firmware.
Jul 03, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 Vision Router Logo
315 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
