Question about X2Gen MG19MY 19" LCD Monitor
MW19R X2gen 19" LCD Monitor goes black after 5-15 sec. A couple of fixes on line were to replace capacitors with larger ones. If this is what you recomend, please tell me 1. location and size of old ones and 2. size of new ones
  • pearson1_dj Oct 07, 2008
    screen goes blank
  • agent_009_87 Nov 19, 2008
    I have the same problem with my mw19u. When I booted up my pc I would have to turn the monitor off then back on. Sometimes I would do this a couple times and it would stay on for good and other times I would go through this for a while before it would stay on. My power light on the monitor stays green when it goes black. If it was the power supply wouldn't that light go out? I did notice yesterday while messing with it that I could see a dark faint image of what was on the screen like the back light wouldn't stay on or something. I keep hearing about the capacitors being replaced in these monitors. If this is a good fix I would like to know which ones and if they need to be larger or same. I could use some good details.
The only solution I have found to work until next time you shut down or reboot is to open the menu, go to Tool Icon and press and hold Reset button for a few seconds. You may have to do this several times before it "takes". Sometimes you may have to press Auto and Reset simultaneously. It is probably not due to your computer, or cables, or connection, video adapter, or board.
Posted on May 04, 2009
  • 905 Answers
It seems the power adapter is failing on these might want to check yours
Posted on Oct 16, 2008
    Problem Solver:
  • 10 Answers
I fixed my monitor! I took it apart and pulled out the inverter board. I then removed the three capacitors on the board. Two 220uF25V and I believe a 47uF35V. Went to Radio shack and bought two new 220uF35V (I don't believe changing the max voltage made a difference.) and a 47uF35V Capacitors for $5 all together. Soldered them in and turned it on. Victory! It works again. It seems that this monitor is just made with cheap capacitors and they quit working. One note when replacing capacitors. Make sure you have the polarity right. It is marked on the board by a shaded in half of the capacitor outline and on the capacitor but a line on one side with negative symbols(-). I have seen capacitors installed wrong and they blow up, lol.
Posted on Apr 29, 2009
After hooking up my Dell to the monitor it displayed a message ! " Out of range ," the monitor then went black . How do I fix it ?
Your screen resolution or refresh rate is set out of limits for the monitor. Check your monitor documentation to determine the correct resolution and refresh rates for the monitor. Then reboot the PC, go into SAFE mode, then re-adjust the display resolution there. Once you reboot after that, the monitor should be fine.
Nov 06, 2013 | X2Gen Mw19r 19" LCD Monitor
MW19r powers up but sceen remains black
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Capacitors kit: he can make you a set of caps for you.
Oct 08, 2010 | X2Gen MG19VT 19" LCD Monitor
My 19 inch x2gen mw19r monitor just went black its still on but wont display a picture so now im using my old tube monitor want to fix the x2gen
titter101, You left out telling us the "DATE of MANUFACTURE" for your unit. You will need to use CRT unit while researching info on x2gen mw19r unit. If unit out of warranty, then you or qualified technician will need to do the investigation and repair of unit. Read the fixya profiles of "budmrtn" , "buddymc" , "12fixlouie" to see if a DIY repair will work for you. 12fixlouie
Aug 16, 2010 | Computers & Internet
Screen goes dark after 1minute, power lite stays on
Possibly the lcd ccfl inverter. Ebay sells universal ones for 9 to 25 dollars each. Monitor repair knowledge needed to replace this part.
It could also be your external power supply if it is not OEM. Or if it failing under a load. If the picture is good when it is on, I always start looking at the power supply and the ccfl inverter/transformer. Please understand I am not an expert on LCD's I just seem to get lots of failing ones. ---Hope this helps.
Jul 25, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
X2GEN 19" Monitor
becauce of overload such a problems are come please disolder path of an eht and look whether smps gives output or not if smps gives output contineusly then replace eht
Oct 27, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MW19R picture goes out after 5-20 sec.
First of all inspecting all the caps closely...see if any caps has a stress mark like a pluffed on top. Those with a pluffed replaced with the same type of voltages that mark on the side of a caps. Those with no pluffed need to tested with ESR meter to see any leaked. If it leaked replaced those too...
Have fun!
Sep 23, 2008 | X2Gen MG19MY 19" LCD Monitor
Black screen
It's seems your backlight inverter are burnt out...Get a new one..or repaired old one by yourself.
Here how it done...need to replaced a new capacitors. Good lucks!
Aug 19, 2008 | X2Gen MG19MY 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
353 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
