Question about Epson ACULASER CX11NF All-In-One Printer
CX11NF noise My printer prints fine, except that it makes a large grinding noise right before the paper spits out. How do I determine what is making teh noise and how I fix it?
  • Anonymous Jan 04, 2009
    my printer stylux sx100 is new i unpacked it tryed it out but it makes a grating noise before it starts to print
    Scholar:
  • 78 Answers
It sounds as though the noise is coming from you fuser assy. this is the last thing that touches the page before it exits the paper path. The most likely scenario is that the bearings in the fuser are gone and you will need to replace the fuser. the fuser retails for about $450 au.
Gremlin11
Posted on Dec 10, 2008
Service manual
Any time I hear that complaint I cringe. Not because of the noise but what it might be telling me. I usually hear that noise as the hot roller bushings &/or the main gear that drives the fuser is cracking or already cracked and is ready to fail. This causes the roller to bind up hence, the grinding noise. Sometimes a drum can seize and that will also make that sound but if you're able to print OK that is probably not the issue.
Oct 24, 2013 | Epson ACULASER CX11NF All-In-One Printer
Will not feed paper and makes a horrible grinding noise.
clear paper feed roller with cloth and water or alcohol, if necessary replace roller
Jan 28, 2011 | Epson ACULASER CX11NF All-In-One Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
I have seversal problems -- The Scanner Lock is on and I can't figure out how to turn it off. Now I can't copy or fax. The machine makes a grinding noise when I turn it on. I think this started after...
The lock is a slide switch next to the large glass when you open the top cover, when it is locked the scanner can't move and makes a grinding noise. It's easy to bump into the locked position and easy to unlock.
Sep 02, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
CX11NF "Paper Jam" and Noise
Mine use to do this, I changed paper type and it has not done it since. I was using recycled paper now I use HP All in One printing paper for Lasers and I do not have the noise.
Oct 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
There is two sensor one paper in and paper out any one or both
Sensor not working find sensor and check it for physically working or not
Feb 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
