Cover removal to access parts.
How do you remove the cover from this old IIBM Aptiva, 712 Model 2144-83P?
I finally found a web site that is devoted to the unofficial support of IBM Aptiva computers. http://home.ptd.net/~don5408 This site had graphics showing what to push in what direction to get the thing open.
Posted on Sep 24, 2008
How do I change the lamp in GE microwave model je1590sc001>
The lamp is located inside the oven. You have to remove the outside cover to access the lamp asembly. You should be aware that removal of the cover exposes potentially dangerous voltages. With the cover removed, remove the old lamp and instal lthe replacement. Reinstall the outside cover.
Feb 17, 2015 | GE Microwave Ovens
How do i change spark plugs on 2.4 2012 equinox
1) Remove the plastic engine cover. It snaps off.
2) At that point the plugs should be visible. One plug at a time: Remove the spark plug wire, remove the old plug and install the new properly gapped plug, reattach the plug wire. Repeat the process for all the plugs.
3) Replace the plastic engine cover.
Aug 25, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
How to know a vehicle has timing belt or timing chain? this website http://www.timingchainorbelt.com/ is not working. please advise. Thanks a lot
Most car timing covers are either metal or plastic. the timing chains are usually in a metal sealed cover due to oil being used to lubricate the chain and gear assemblies and timing belts are usually in a removable plastic housing with some sort of access cover to inspect the belt, usually it is a two piece cover where as a timing chain is in a one piece cover. know-vehicle-timing-belt-or-timing-c3hyvbb5dw5lz1xfja5a3wpz-4-0.jpg
Aug 13, 2013 | Vehicle Parts & Accessories
Do I need to remove the front cover to change the front crankshaft seal?
Both!
The pulley only allows you to access the cover, and the cover needs to be pulled to push the old seal out and push the new seal in!
Jan 20, 2013 | Chevrolet Vehicle Parts & Accessories
Stopped running. About 4 years old. Won't take charge. Moderl # 8865 XL
Most likely, the batteries are the problem. You will find the correct battery type for model 7735x at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the screws. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 21, 2010 | Norelco 7735X Electric Shaver
How to remove batteries from a philishave razor model HQ 6863
You will find the correct battery type for model 6863XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 19, 2010 | Philips Health & Beauty
How do I remove the cover to get to the batteries. how do I remove the batteries
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Oct 08, 2010 | Norelco Quadra Action 7864XL Electric...
How do you change the batteries
To replace, you will need to remove the back cover by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Oct 01, 2010 | Norelco Quadra Action 7864XL Electric...
Missing sound drivers for IBM Aptiva - win98SE
you can find the driver in this site called sofpedia, or else if you know to remove the side cover of your system open it and see the mother boards left-bottom corner you can see a small chip with no like ALC5246,AD888, CMI, like this if find that no your problem is solved.
Oct 20, 2009 | IBM Aptiva E 2170 PC Desktop
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
