Question about GE Refrigerators
Side by side ERS2022DA CC, LZ254888 Eterna Series year 2000 frig side warm frezzer side ok but frost buildup on the back of frezzer. I defrost and clean, vacum back and underneath. after two days same problem.
  • 1462 Answers
SOURCE: Air Flow to Refrigerator keeps getting blocked by ice buildup
yes it is but check any plug and socket wiring as well
Posted on Aug 31, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
  • 25 Answers
SOURCE: Freezer not freezing
your defrost timer or defrost heater could be bad,
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: frezzer is icing up and frig is getting warm . we
Hi, If you are having frost build up, you will need to remove the rear panel inside the freezer. Unplug the refrigerator. You will need to test the bi-metal switch that is located on top of the evaporator coil and it needs to be cold when testing it. If the bi-metal switch shows an open circuit, it will need to be replaced. If the switch shows a closed circuit, test the defrost heater the same way.
If both parts show they are ok, you will need to replace the defrost control which is located inside the fresh food section in the control panel.
If it is solid ice that you find after removing the freezer panel. the drain under the evaporator coil is plugged and will need cleaned out.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
SOURCE: Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Posted on Jul 28, 2009
Why is my whirl pool frig leaking onto the floor and how can i fix it
Frost buildup inside the **** tube that leads from the evaporator coil to the bottom for defrost condensate tray is plugged. Try giving the unit a manual defrost by unplugging and leaving the doors open all night 12 hours. If the problem comes back you may have to take the cover off the evaporator coil and use a turkey baster to force warm water to flush out the tube.
Mar 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side that frosts up in the middle back ofthe freezer and the frig part gets warm. I have $200 in it and still no resolution. Bought new in June '04. I defrost for 24 hours, turn it on and...
If you can locate the defrost timer and advance it to the defrost cycle you should be able to see the defrost elements glow behind the rear panel in the freezer. Do this before the freezer gets too frosted up. If you can't see the glow then there is a problem with the defrost heaters or the defrost thermostat. Unplug the frig and remove all the racks in the freezer. Remove the screws holding the rear panel on. Locate the two heaters and check the resistance. IF open, replace heaters. IF ok check resistance of the defrost thermostat. IF open when cold, replace defrost thermostat.
If replacing heaters always replace defrost thermostat at the same time. It will save you doing so at a later date
Dec 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My frezzer side is working ok but the fridge side is warming up now at 15 cant lower the temperature
I would check the defrost timer. Most of the time when you are having a problem such as this, it is due to frost/ice accumulation on the evap coil, due to a faulty defrost component. Start with the defrost timer and work from there. Hope this helps
Sep 22, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Jul 09, 2009 | GE Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator not cooling
Check inside back wall of the freezer for frost buildup. It would be a sign that the defrost system is not working and the coil inside the back wall is frozen over stopping air circulation to the refrigerator.
Defrost system has a timer that energizes a heater and a defrost termination switch which shuts off the heaters when the coil is warm enough for all ice to be melted. If you have the frost, locate the defrost timer and turn the clutch head screw clockwise SLOWLY until you hear one audible click, the compressor will shut off and the system will be in defrost. After 18-22 minutes the refrigerator should restart automatically. If it does not restart after 25 Minutes turn the timer screw again to the second click. Refrigerator will then start. Replace the timer.
If it restarts after the 18-22 minutes and does not defrost ether the heater or defrost thermostat is bad.
Jun 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
