Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 Thermal Ribbon Ripping after printing
I have a S600 that recently exhibits the following problem frequently. We print a shipping label, and it would usually rip the used portion of the thermal ribbon. I tried adjusting the ribbon tension, but neither setting helps (normal or low tension).
Any suggestions as to what it could be? I asked our warehouse manager and he says that the ribbons are the same ones he has been using for the last 3 years (uline).
    Problem Solver:
  • 6 Answers
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
Posted on Sep 25, 2008
    Problem Solver:
  • 9 Answers
Try using other compatible ribbon.. maybe your ribbon is not compatible to your media used
Posted on Oct 31, 2008
Ribbon is melting
Hi
You have the heat setting in the driver set too high.
Lower the heat setting to the lowest possible setting, the print quality will probably be poor then gradually increase it by 1 until print quality is good.
Regards
Rob
Plain, Printed and Barcode Labels
May 11, 2012 | Zebra Stripe S600 Thermal Label Printer
Can a Zebra S600 printer print labels without using a ribbon?
Yes it can but you have to use DIRECT THERMAL MATERIAL. That eliminates the need for a ribbon but what most people don't realize is that a ribbon is almost like "Oil" in your car. Direct Thermal material is more abrasive and will wear out your printhead much faster. Now if you don't print lots of labels that may not be a big deal but if you print 500+ labels a day then thermal transfer may be a better choice in the long run. Printheads are one of the most expensive components of these printers.
Regards,
mikeo@acebarcode.com
Feb 24, 2011 | Zebra Stripe S600 Thermal Label Printer
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Jul 18, 2010 | Zebra Stripe S600 Thermal Label Printer
I am having problems with our Zebra Stripe S600 if I ask it to print 500 labels it will only print 3 then I have to line the label and ribbon back up, any advise would be gratefull
Recalibrate the printer, it seems it might have lost it's calibration. Chekc and clean all sensors in the paperpath with Isopropyl Alcohol.
Jan 21, 2010 | Zebra Stripe S600 Thermal Label Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
Labels print out of position
Try cleaning the media and ribbon sensor you can open it and try clean it, it possible that there's a lot of dust or even small particles at the sensor path..
Jun 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
529 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
