Question about Mitsubishi WS-65819 TV
Mitsubishi WD-52725 I have recently purchased a mitsubishi 52 inch HDTV and it as worked fine until recently I can hear the tv show but can only see black and white tiny rectangles all over the screen and the buttons on the tv well the lamp buton isn't lit so I assume the lamp is fine as well as all the other buttons but one button stay lit and that's the timer button can you help because I can't afford for some one to come out here and check it for me!
  • delpoley Mar 27, 2009
    i have the same problem on my wd 52725. reset does not fix my problem. has anyone solved this one yet?
    Scholar:
  • 188 Answers
Manual should be available here to look at or dwonload. I copied the reset instructions. You may have to go through some set-ups after a system reset. Good Luck.
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
System Reset
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
Posted on Sep 23, 2008
My WD-52725 mitsubishi 52 in tv is not working i turn it on and the fan starts but then i get a whining sound for about 5 too 10 seconds then it stops the sound for cable is working but no pic. then the tv...
Hi:
This sound is an indication that the color wheel is faulty in the light engine, with mits sets you must replace the entire optics engine. You can purchased used light engines or have your sent in for repair. Try this site for rebuilt engines www.tristatemodule.com
Mar 10, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Do u know the dimensions of the rear projection/it quit working
These are the dimensions of the TV itself (including the bottom piece)
The height of the TV is 37.2 inches tall
the width is 49.6 inches wide
the depth is 17.4 inches deep.
the weight of the TV is 132.5 pounds (just thought you would want the weight as well if you are considering purchasing a stand)
I hope this helps and good luck!
Feb 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Have a 52 inch Mitsubishi TV. Just replaced the
Call Mitsubishi the chassis needs to be rebuilt on this set they have been paying for the parts but you will have to pay the labor.
Oct 13, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Television suddenly turns off.
Try to get a firmware update. THis happened to me and I got a firmware update from Mitsubishi and now all ok. Call Mitsubishi
Nov 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS-65819 TV Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
