Question about Frigidaire Refrigerators
Slow water flow - Frigidaire Refrigerators
  • 958 Answers
Could be your water supply pressure or could be a clogged filter if you have one.
tnx 4 using fixya,
drcool
Posted on Sep 23, 2008
Can the water flow be made faster?
A SLOW WATER FLOW IS USUALLY THE RESULT OF A CLOGGED OR INHIBITED WATER VALVE LINE OR HOSE. IF THE LINE IS FROZEN OR HAS DEBRIS IT WILL SLOW THE FLOW
May 13, 2014 | Samsung RS2630WW Side by Side Refrigerator
Water flow is slower than the normal. we check the saddle valve, lately we changed the water filter from that day on water flow is very slow.
In some models it creates an automatic by-pass when the filter is removed. If this is one of those models remove the filter and use the dispenser with it out. If you get good pressure now, it indicates a problem in the filter housing. If it's still slow it could be due to low supply water pressure or a defective valve. You can check the water at the valve inlet and outlet. First turn the inlet (main) water supply valve off. Now disconnect the water inlet line at the valve and place the end of it in a pitcher. Turn the water valve back on and check if there is a good solid water flow. If the water flow is good reconnect the water to the valve and now take the water line loose on the back side of the valve. Activate the water dispenser and check how the water flow is coming out of the valve. You will probably need another person to help you with this check. If the water seems slow, then the valve will need to be replaced.
Jan 16, 2011 | Maytag MZD2766GES Side by Side...
Water flow is very slow almost a dribble - we have changed filter and that did not improve the flow When frig was new water flow was very high
ck the walve that was installe on cold water it is gone bad and needs replace ment . do use one that you drill pipe 1/4 in and it alow the water to flow . the small pin pircing type will corrode over and slow the wate or stop the water .. mm
Aug 17, 2010 | Maytag MSD2656G Side by Side Refrigerator
Can water flow be adjusted water comes out very slow
Yes, providing the water filter has been changed regulary. That would be number one reason for water slowing down. If you hae done that we will work with supply, Sea Breeze
May 19, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Cold water fills very slow, hot water is fine
check your cold valve switch inside machine. might be sticking ,slows down water flow , alkali ,hard water deposits may be the cause of most,make sure it is free flowing rod assy . move manually to activate.it is an 1 hour labor min
Mar 19, 2010 | Kenmore 800 7982 Dryer
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
Water flow on my Maytag ICE20 is very slow.
The orifice into the filter is getting clogged. A toothpick or small paperclip will clear it.
Jul 21, 2009 | Maytag MFD2562KE Bottom Freezer French...
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Refrigerators Logo
200 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
