Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Vertical white line ..right edge
Akai PDP4295ED plasma 4yr old picture great.Last week any time after running 2 hrs a white 2 pixel wide line appeared on right edge of screen.Intermittantly it would go off then on spontaneously.Tapping on center of bottom frame some times it would go off Could it be cold solder problem
  • rmck46 Sep 24, 2008
    where should Iook for solder problem??On circuit board or panel edge?
  • rmck46 Sep 26, 2008
    What area of panel edge left right top or bottom is suspect
  • 4,234 Answers
Since this set is no longer under warranty, open it up and reseat all of the connectors and cables. The signal levels inside this set are extremely small and any poor connection can cause noise that can show up this way. Tink of hte plasma as an X-Y plane. You have a signal problem for 2 columns on the Y plane at that location. This could be a component problem as well, but that is unlikely. Try to reseat everything and update this. Please note that the pibbon cables from the plasma panel to the PC boards are extremely fragile. Be careful not to tear any of them as that would require you to replace the entire panel.
Please keep us posted.
Dan
Posted on Sep 26, 2008
  • 2,326 Answers
Vertical bar failure:
Check all connectors.
Check peripheral circuit and connecting of the XR and XL boards.
These boards are located under the video/main board and they are connected to the main digital controller board and from the XR and XL to the screen.
Posted on Sep 24, 2008
    President:
  • 1,952 Answers
Changed the capacitors C280, C302, C320, C323 - 100UF 35 VOLTS. Bought em at Radio Shack $5. Took about 2 hours cause I'm slow. Capacitors are in a group on the board with all the AV connections.
  • mohammed marika thambi
    mohammed marika thambi Sep 24, 2008
    i think best way to take itto an autharized service station to troble shooting to trouble shoout yourself and replace components is difficult ityou have privieous experianceit in repairing electronic printed boards and must not have at least some basic tools
    on circuit board
  • 1,031 Answers
Try this USING THE REMOTE. 1-PRESS BRIGHTNESS 2-PRESS THE FREEZE KEY 3-PRESS THE MENU KEY 4-PRESS ENTER THIS WILL RESET EVERYTHING.hope it works You could have a burn-in from the speakers mounted too close to the set or games being played on the screen for a plasma.
. , disconnect everything from the set except for the power cord, turn the set on and see if the lines are still present. If they are not, the problem may be something external to the set
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. There could the problem with solder or loose connection in the tv....
  • 1,800 Answers
Its a liquid cristal tarnsistors problem this tproblem occurs when a bad voltage goes to those transisitors.
u need replace those transistors and its not an esay task!!
best regards
  • 2,071 Answers
It would go off when tapping,yes it is a symptom of loose or cold solder,joint of the parts.You must reworks or resolder the solder joint in vertical section and check also the capacitor there for firm solder...
Hope this may help you;
Regards,
VOTIT
Pdp4295ed will not turn on. I can hear a bump thru the right speaker but nothing else
This is the "Akai PDP4295ED - 42" plasma TV", that we're talking about?.. Has is 'fallen off of the back of a truck', or had you -actually- purchased it?! What is their support saying, in that case? :)
Maybe get a starting point... From where you can search for a manual, or support, such as:
http://www.cnet.com/products/akai-pdp4295ed-42-plasma-tv/specs/
Nov 14, 2015 | Cars & Trucks
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
Oct 30, 2013 | Zenith Z50P3 50 in. Plasma TV
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Red vertical line appears intermittently
you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
Jan 23, 2009 | Hitachi 55HDX61 Television
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Vertical white line
Dont touch it just keep it running. one of the days you wake up and it will vanish just as it appeared without cause. This is because it has happened to me once with my Philips 42. the don
Aug 09, 2007 | Philips 50PF9630A 50 in. Plasma Television
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
95 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
