Washer will not spin or completely drain
Washer began to give beeping signal when it got to spin cycle,lid -ock light I think was blinking, machine seemed to hve drained but would not spin & lid would not lock. I've checkecked leveling and it seems ok. Yesterday I ran a cycle without clothes with same result but seems to be seems to be 3 or 4 inches of water stin in machine.
  • Anonymous Dec 14, 2008
    I tested lid switch and it seemed no problem. What could be the next reason my washer doesn't spin?
  • 958 Answers
You could have problem with door lock. or lid switch. this part senses if the door is close.
if it is not functioning, it would interpret it as an open door and will not spin.will not drain either.
tnx 4 using fixya,
Posted on Sep 23, 2008
Will not fill with water,and continually beeps
Hi Shirley, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Washing Machines
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here--->
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
I have a GWL11 Fisher Paykel washer. It was running fine then it was beeping and had stopped-- the spin light was the only one left on, although water is in it. Basin looks lower than I recall. It won't...
Hi just read you posting.Now when the machine was beeping was the spin light the only light that was on while it was beeping?If this is the case then my manual tells me your Motor Controller is faulty and needs replacing.Please confirm which light was on when the machine was beeping because the motor controller module is not cheap.Looking forward to your reply.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
This would be due to the lid switch, the machine is designed that it will only spin and drain with the lid closed, if the lid switch goes bad the machine thinks the lid is open. Here is a link to a video that shows how to replace the switch.
Lid Switch
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
431 people viewed this question
Top Washing Machines Experts
