Question about Minolta Office Equipment & Supplies
I have a minolta RP600Z microfiche reader. It is showing a code "C4". The code chart does not indicate a cause for this. Have any ideas.
2007 sports trac wrench light on, abs light on and advance track light on. where to go
Hello Alfred,
The dash warning indicators are showing problems picked up by your vehicles on board computers.
The first step to understanding what all these warnings relate to is having a diagnostic reader reveal the codes that have been registered. This reader is called a OBDII code reader.
Some auto parts stores provide a free diagnostic summary. I think Auto Zone is one of these retailers that will provide this free service.
After you have the codes go to Repair Pal here:
OBD II Trouble Code Chart to find the descriptions for your fault codes.
Jul 21, 2017 | Cars & Trucks
2004 ford explorer airbag indicator blinks 4 then 2 code 42 what can i do?
Have a dealer or repair shop scan the truck
for body codes
They will be enhanced & not avail for free or with
a code reader
Need factory reference material to look them up &
follow diagnostic charts to resolve
Mar 05, 2013 | 2004 Ford Explorer
MIL ABS on / off ramdomly. No auto problems to indicate a cause.
You need to have the body computer scanned for trouble codes. Most simple code readers will not access body computers.
Aug 04, 2012 | Mitsubishi Montero Sport Cars & Trucks
I have a Minolta EP1054 (in the Middle East) I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared...
was the power on when you depressed the small switch? you mite have damage the lamp in the fuser or the control board. very old machine find the parts and replace them
Apr 10, 2017 | Konica Minolta DiALTA Di200 Copier
My Mazda5 "Check Engine" light is on. Fault code
FOR CODE P2106 (INTERNAL ENGINE OFF TIMER PERFORMANCE) THE FLOW CHART WILL LEAD YOU TO BELIEVE ITS THE PCM. THIS WILL PROBABLY NOT FIX IT. FIRST CHECK TO SEE IF NON FACTORY SPARK PLUGS HAVE BEEN INSTALLED. IF THEY HAVE THIS IS MOST LIKELY THE CAUSE.THEY WILL PRODUCE INTERFERENCE THRU THE COIL WIRING AND CAUSE THE PCM TO THINK THERE IS A PROBLEM. SIMPLY PUT FACTORY PLUGS BACK IN ENGINE AND CLEAR CODES.PROBLEM SHOULD BE GONE.I HAVE BEEN THRU THIS. SID CODESPOTI (SERVICE MANAGER)STOKES MAZDA, CHARLESTON,SC
Jan 22, 2011 | 2007 Mazda MAZDA5
Service code p88, what does that mean?
this means the automatic exposure needs to be adjusted and there is a special chart you have to put on the glass andd enter 47 mode and run code 98 to automaticaly run the adjustment repeatedly when the adjustment is complete the center copy density indicator will light up yopu cabn try it with a blank peice of paper but you are supposed to use the aes chart for the adjustment
Aug 24, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
56 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
