Question about Curtis CM27002S 27" TV
CURTIS MATHES 27" tv model cm27001S
Looking for a manual and the remote codes. Will only bring in 2 cable channels
  • dialbecky Nov 05, 2008
    i have a curtis.mathes tv i need the code to tv model no is cm32020s thank you
  • 133 Answers
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
mghall69
  • 12 Answers
SOURCE: need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
Posted on May 09, 2009
frankzcomput
  • 268 Answers
SOURCE: Need code for Cable remote to work tv
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Posted on May 23, 2010
gopakumarg43
  • 74634 Answers
SOURCE: Hi. Can you please tell
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Posted on Dec 23, 2010
gopakumarg43
  • 74634 Answers
SOURCE: need owners manual for curtis mathes tv model #cm32020s
Click here to downlaod the user manual to your tV.
Posted on Apr 29, 2012
I have a Curtis mathes 3250 W. model no. CM27001S Ac 120v 60Hz 110w manufactured in November 2001 serial no. 39ZRB68225Y we are trying to hook up our direct TV satellite to our tv we have hooked up the...
Rebecca,
You should only need to connect the red yellow and white wires to the TV. Make sure your TV is set to the aux input/video input. Sometimes this is a channel, sometimes you have to change the video source. There might be a dedicated button on your remote for this. I believe your TV is only standard definition (non HD).
Greg
Sep 24, 2017 | Curtis-Mathis CM19011 TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Code for urc-3021 for curtis mathes tv
I found this info stashed away in One-for-all's archives where nobody is supposed to look - very helpful of them! One of these codes should work for your TV:
0047, 0054, 0154, 0451, 0093, 0060, 0702, 0030, 0145, 0166, 1147, 1347
Test each code for standby, volume and channel fuctions. If one doesn't work or only partially works, try the next one. If the best you can get is partial control, then stick with that one. These are the only codes available for Curtis Mathes TVs for this remote model.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | One For All URC-3021 Remote Control
Try
Thanks
Frank
Live-Tech
1-888-361-8511
May 15, 2010 | Curtis KCR2610 7 in. Portable Television
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
Feb 17, 2010 | Curtis-Mathis CM27101S TV
Need code to program Zenith remote control
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Remote control codes for general instruments cable box
i have a curtis mathes tv called an itronics and i need a remote controll code for it
Jan 15, 2008 | Nikon MC-EU1 LCD Remote Control
Curtis CM27002S 27" TV Logo
260 people viewed this question
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
