Question about VeriFone OMNI 3200 (P092-101-10) Printer
Will not print
My 3200se will not print a receipt. The paper advances but no print. I've checked the paper, including changing rolls. I've unplugged the machine and plugged it back in to reset it. Also had the machine reprogrammed, but it still will not print. Wht is the problem?
You are using the wrong power cable, most likely changing the power cable will fix the problem
Posted on Feb 04, 2012
  • 18 Answers
First, make sure you are using thermal paper. Or, it is feeding from the bottom of the roll.
Posted on Mar 26, 2009
Dear sherrgott,
My name is ken, me and my collegue specialize in repair and sell credit card terminals wholesale and single quantiy. From your description, your printer mechanism or printer seem to be defective. If you like to get it fixed, call me at 714-495-0428. Our business is located in orange county, california.
Posted on Sep 26, 2008
  • VeriFone Master
  • 2,794 Answers
The thermal print head probably needs to be replaced on the unit. You will have to contact Verifone to find out how to get it fixed.
Here
Posted on Sep 23, 2008
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Receipt won't print on royal alpha 1000ml
Make sure you use thermal paper and no other kind.
May 12, 2012 | Royal 29043x Alpha 1000 Ml Cash Register
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
We have a Star TSP800 and when the last roll of paper ran out, we replaced it as we normally do. When we put a new roll in and shut the lid, the cutter usually comes across and the red error light switches...
Dear Star Customer
It sounds like you have a hardware issue. Please open the lid and take a photo of inside the printer and forward it to us at support@star-emea.com, it will help us find out what the problem it.
Best regards
Star Support.
Jul 16, 2011 | Star Micronics Receipt Printer TSP800...
The star tsp700II receipt printer I have was working great and then one day it started feeding paper before each receipt. So it wastes about 6inches of paper on every receipt. I cannot figure out what...
Our Star TSP700II leaves about 1/4 inch of unused paper on the roll when the error light comes on and the printer stops printing. Is there any way we can make an adjustment so that we're not wasting so much paper?
Oct 22, 2010 | Star Manufacturing Star TSP700 Receipt...
Receipt won't print after paper change (and it IS thermal...)
not knowing what the model is I suspect the machine suffered a power surge or got a spill
Aug 26, 2009 | Casio Parts Cash Register PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Sanyo ECR 240 Cash Register
Hi. These are very rare, so I don't have info on them. However, Sanyo usually have a receipt on/off button on the machine if that model can have the paper turned off. Since it is a single roll printer, it may be set to journal mode where it will always print. To change this, you would need the programming tables. Do you have a manual for it? If I can check the tables, we can see if it has the on/off function.
Mark
Nov 07, 2008 | Casio Parts Cash Register PC Desktop
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
VeriFone OMNI 3200 (P092-101-10) Printer Logo
232 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
