Question about Dualit CTS4E 4-Slice Toaster
Toaster will not heat
I think that yesterday when it was being cleaned it must have gotten wet inside, the timer works but no power....
  • 706 Answers
If your timer works but no heat and you think you may have goten water inside the toaster area.. chances are you've dislodged the heating element itself. If you shorted it out, you would probably take out your circuit breaker or fuse from the receptacle that provides power. If you are relatively handy, UNPLUG it, then look at where the heating element penetrates the oven compartment to see if it looks normal ( meaning that it is passing thru the wall of the oven ok) then check the other side ( you may have to remove a cover) to see if the wires providing power to that element are still attached. To be honest, I do not know this particular brand that well but it does sound like a fundamental problem that should be easily addressed. Good luck..
Posted on Sep 23, 2008
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Two filaments not heating up
We had the same problem. I took off the bottom plate, cleaned the toaster, reseated all of the connectors on the heating plates, timer, and switch, and the toaster started working again. Only one connector was slightly loose (but it was still connected with decent contact). I am not sure what fixed it. If that did not work, my next step was to purchase replacement parts online and swap out the switch, timer, and heating plates (in that order). We have an older model than yours, but I suspect that the parts are similar. The parts all look very easy to replace. These units are intended to be repaired and not replaced.
Jan 29, 2011 | Dualit 31213 3Slice Toaster
Dualit 4-slice toaster stopped toasting, never heats up
Jan 27, 2011 | Electra Dualit 40416 4Slice Toaster
No heat when turned on
Jan 25, 2011 | Dualit 40352 4Slice Toaster
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Do you work on toasters? after cleaning toaster, heating elements not all working
wiring may have gotten wet while cleaning try using hair dryer,blow through all the vent holes for a few minutes
Oct 06, 2010 | Oster Kitchen Appliances - Others
The heating elements don't come on.The timer is working as you can hear the clicks but that's about all.
We had the same problem. I took off the bottom plate, cleaned the toaster, reseated all of the connectors on the heating plates, timer, and switch, and the toaster started working again. Only one connector was slightly loose (but it was still connected with decent contact). I am not sure what fixed it. If that did not work, my next step was to purchase replacement parts online and swapping out the switch, timer, and heating plates (in that order).
Feb 11, 2010 | Dualit CTS4E 4-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Toaster Does Not Work...
You may hve gotten some moisture inside the plug, just leave it for a few days to let it dry out, if the problem persists, send an e-mail to the following:
li199065@hotmail.com
Oct 01, 2007 | DeLonghi RT200 Retro 2-Slice Toaster
Dualit CTS4E 4-Slice Toaster Logo
190 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
