Question about Brother IntelliFAX 1270E Plain Paper Fax
Black lines on faxes
Whenever i fax/ copy something there are two black lines that run all the way down the right side i already tryed to clean the inside of the machine it didnt help what do i do?
    Genius:
  • 2,120 Answers
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Posted on Sep 23, 2008
When we recieve faxes they have black lines running down the entire length of the page. I have already changed cartridges and am wondering if there is something that needs cleaned? What can I do?
You have to determine if your FAX is the problem or the sending FAX has the problem. The first thing to do is make a copy or print a report. If it comes out clean you FAX is NOT the one with the problem. The sender has to get their optics cleaned.
On the other hand, if it's still "streaky" then your fax has a problem. First off remove the cartridge and look inside it, if you see toner get a can of compressed air (sold in office supply stores to clean keyboards) and blow out as much as you can. I suggest taking the machine outside the toner dust can make quit a mess. Make a few copies (5 - 10) to check it out. Each copy should come out with less misplaced toner.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
Black line
Open top and clean the scanner glass
Jun 17, 2010 | HP 640 Inkjet Fax Machine
Black line down right hand side how do i get rid
Open the original feeder of the fax and look for dirt on the platen(thin glass ) glass usually white out or postit glue clean with damp rag or isopropyl alcohol
Good luck
Apr 19, 2010 | Office Equipment & Supplies
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Black line down middle of confirmation copy
You need to remove the toner cartridge if fitted pull out the toner holder, making sure the opening is on the top, if not the toner will spill out, set this to one side and clean the toner holder thoroughly.
Mar 18, 2009 | Office Equipment & Supplies
Same black line on right side problem
take out your drum unit and make the blue plastic corona wire cleaner on the drum unit is pushed all the way over to right side. see if that helps.
razors
Dec 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
182 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
