Question about Thermador Professional Series PO301 Stainless Steel Single Oven
Thermador SM272 - Oven not heating after self clean cycle
My oven was working fine till I ran the self clean cycle. Since then the owvn does not seem to heat up. I have someone comign to look at it this evening. I want to make sure I know the areas they should be looking at. What could be the issue?
Yesterday I had this very unhelpful repairman that said the computer is not working but could not explain how he deduced that by just looking at the oven and the schematic and not chekcing anything out. He actually got upset when I asked him how he knew it was the computer....incredible!
  • brentlawyer Apr 20, 2009
    Top Oven stopped working after self cleaning was run. I checked the top elements in the bottom oven and the elements are working fine. The top oven only is not heating up.
  • Thermador Master
  • 5,568 Answers
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Posted on Sep 23, 2008
Lower element does not heat up.
did you test it? could be bad. may be relay board, burned/broken wire, safety thermo or a bad solder connection on the board.
Feb 01, 2014 | Thermador SM272 Electric Double Oven
Lower burner doesn't heat up
do you get 230v across the 2 terminals when on? could be a bad solder connection on the underside of the relay board.
Jan 30, 2014 | Thermador SM272 Electric Double Oven
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2010 | Thermador SC302T Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Thermador Professional Series PO301 Stainless Steel Single Oven Logo
523 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
