Whirlpool model ED22DW will not stop making ice. Ice is falling all over the inside of the freezer. How do you adjust the arm so it will stop making. The only thing I found was that the wire arm either shuts it off completely or just keeps running. Where is the level of ice control?
SOURCE: whirlpool refrigerator model # ED22PE
The ice coating usually means that your door was left slightly open. Did the ice maker work after you cleaned up the ice?
SOURCE: ice maker sensor arm
the arm is hung up on a srcrew that is on the divider wall to the right of the icemaker pull the arm off the screw. The icemaker is a mechanical one so the arm will not just drop down so put the ice bucket back in and turn the icemaker back in the control panel further problem call customer service for assistance for over the phone help 1 800 222 7820 they will be glad to assist their customers unlike other manufactures.
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
SOURCE: Ice Maker not going through complete cycle
what kind of unit is it? there are several possibilities
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
same problem
