Question about Stanton STR8-30 Turntable
STR8-30 Pitch control problem
I've heard this from one other person so I know it is an issue because it is weird on how it would ever happen. On both of my Stanton STR8-30's the pitch control does not have the range from 0 to -2.
when you have the slider at 0, the red lights are still... as you move the slider up (slower) the light remains still and then in an instant ( i mean nano ) the red lights jump was slower and now you are at -2 on the pitch when you've barely moved it. This has happened on both of my tables. WTF?
  • 42 Answers
SOURCE: STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
Posted on Jan 25, 2009
SOURCE: Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Posted on Feb 18, 2009
repairtech99
  • 767 Answers
SOURCE: pitch adjust doesnt lock between 0% and +50%
There is a chip in the unit called a
phase lock loop ,( P.P.L )its use as station loc
for stereo turner. But the same applies.
Its drifting and unable to hold/lock
the signel is noisy that its trying to
lock on to (open ground) or the VCO
is out eather way it probley needs
to be replaced.
Hope that help a little
Posted on Jun 30, 2009
  • 189 Answers
SOURCE: I just recently bought a used stanton str8 80 but
HELLO
There is nothing more annoying than buying something second-hand to find parts are missing. I've had a look on the net for you and you could try these sites - they might be able to help.
www.HTFR.com and www.djdeals.com.
I wish you luck finding a weight and hope this has gone some way to helping!
Posted on Aug 05, 2009
SOURCE: my stanton t50 turntable plays too fast even when
change the motor is on bad conditions
Posted on Oct 22, 2009
What is the name of the motor that controls where the air blows inside the cabin?
You need a vent control,Its named climate airflow control,This is going to be tough to find,they will only sell it as a control unit,1_27_2013_4_11_20_am.gif
Jan 27, 2013 | 1997 Subaru Outback
I've heard that there are some screen issues with the iPhone 5, have anyone experienced any of them?
I personally didn't have any screen issues with my iPhone 5 although a friend of mine told me that he have experienced a bubble effect. When he presses the phone, no matter where, there were a certain spot on the bottom of the phone that glowed in a bubble shape, you can watch the attach video to see is you got the same problem http://www.youtube.com/watch?v=_4kYbiygU6A&feature=player_embedded
Sep 24, 2012 | Apple iPhone 5
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
Phone freezed
www.youtube.com/watch?v=pMWwcizC144
I've had that happen a few times with my v620. Moto's software is notoriously buggy but it shouldn't be a huge problem. Sometimes my phone will restart, sometimes I have to remove the battery to restart it but it doesn't happen often.
I've heard that if you turn your phone off for a few minutes every day, it can lessen the times it freezes. I don't know if that's true or not but I do it every night before I put my phone on its charger. I haven't. I did a fair bit of research before I purchased my v620 and I knew it had somewhat buggy software. I also purchased it used, so I don't think I had a warranty.
If your phone is still under warranty, I would suggest having it sent it to see if they have firmware fixes for some of the issues. It couldn't hurt.
I love my v620 (I had wanted a v6XX since I first saw the v600 in September of 2003) so I'm okay with sometimes having to restart but if I could get that fixed, I totally would. Call and report the issue to SAMSUNG and if they tell you to call Motorola, call and report it to them, too. By reporting it, you'll help them (I hope) build a firmware fix for the issue. Or, it could just be an issue with your phone and they'll tell you to send it in. I have had this happen 3 times with my i530, and it required me to remove the battery to get it working again.
I have to say with all of my other Moto's this has never happened and am suprised this one does it. It has cost me 2 times missing pages for Investigations which luckily others called me on my other cell to let me know about it.
I would do what MOTOhooligan suggested & call Nextel and Motorola about this, see if they know of a problem with the software & maybe can give you a solution for the problem.
I know next month at our meeting I am going to see the person in charge of our Nextel's to see if he knows anything or will give me a new unit.
May 05, 2011 | Samsung E1075 Cell Phone
Issues with turntables picking up speed when trying to time start off. It's hard to match beats when the table does not start on cue or slowly try to catch up to speed. What's wrong with them?
This seems to be a pitch control issue. controller,
replacing \t,could be worn over time,
SL1200 Technics - if you want a solid long lasting excellence of sound reproduction for many years to come,
I had the same pitch control issue,
happened on one of my decks so I replaced the controller and good to go from there,
Another important tip -
never lubricate the controls sliders with any thing apart from the correct greases or oils applied by the manufactuer,most people dont think of the damage caused by the cleaners they use ,some aerosols eat away the fine oil that lubricates the pitch control sliders making them dry and brittle eventually cracking producing odd random performance issues,
hope this helps,cheers Misterdj
Apr 08, 2010 | Philips gemini XL-500 II Turntable
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on...
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Jan 15, 2010 | Philips Gemini CDJ-20 Top Loading...
Weird noise
secondand third gear but doesnt happen all the timeDo you think is the clutch?Probably going to need more information to diagnose this one. The Buell makes SO much mechanical noise when running it's hard to tell at times if it's normal or not. If it sounds like a handful of nickels in a blender it's probably OK. The only whirring I've heard in over 20k miles on my Uly is the cooling fan.,,,
Nov 10, 2008 | 2005 Buell Lightning XB12S
SAMSUNG YP-Z5 4 Gb MP3 player
Well i heard of a couple of reasons why this may happen, but i cant promise any of these will work but you can give it a shot. 1. there was a couple of issues with older firmware try re flashing with newer version and then formatting it. 2. i heard that in some cases you will have this problem when you have duplicate songs in it, see if you can go trough your music library to see if you encounter an duplicate songs and delete them, its weird i know but i heard that works.
Jul 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Stanton STR8-30 Turntable Logo
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
