Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Start light will not come on,but the power is on
  • Anonymous Sep 28, 2008
    Error code 3813 displayed and then printer will not come on.
    Problem Solver:
  • 12 Answers
STATUS_ERROR_FIRMWARE_ASSERT error code 3813
solution for this one is to powercycle your printer, by turning it off then unplug the power cable at the back of the printer, wait for 20sec. before you replug it back.
then if your printer is connected to a power surge protector or into the power strip
try to disconnect it from there and connect it directly to the main power outlet
hope this will help
Posted on Oct 03, 2008
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
Power steering light on
Is it a petrol or a diesel? Are you sure it's a power steering light? What does the light look like?
Apr 21, 2014 | Peugeot 405 Cars & Trucks
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
92 grand marquis wont start just clicks when trying to start it battery is good starter is good relay is new. what else could be the problem
Make sure the connections to the battery are clean,and the battery post,no grey,or black residue ,this acts as an insulator.Check the ground connection,to the engine.
Mar 10, 2010 | 1992 Mercury Grand Marquis
Car wont start and there is no power to it at all. The security light is on?
do you know if you have an anti-thieft device in your car. sounds like it may be armed and connected to your battery.
Oct 18, 2009 | 1995 Jeep Grand Cherokee
HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Jul 16, 2008 | HP Pavilion zd8000 Notebook
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
135 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
