Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
  • 515 Answers
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
DJM 500 Mixer not turning on
Seems that the power supply is down.
If your not a technician, visit one or bring it to your local dealer.
regards,
Gerard
Mar 14, 2010 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
How do i fix my pioneer djm 500 mixer when i changed the voltage while the power supply was in. without looking at the back of the mixer where it said "caution do not change voltage while power supply is...
Just done the same thing. Remove the screws on the top of the
case and then all knobs, faders etc. One you have exposed the
inside of the mixer you will see a fuse where the power enters the
case. Replace the fuse with a 800ma 20mm fuse and this will fix it.
Sep 16, 2009 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 MIXER KEEPS PEEKING RED SHOWING HI SIGNAL AT LOW VOLUMES
check your input (cables and device)for bad or short circuit cable-bad plug--connection between inner conductor and shield. of the cable(test with new one)------you can disconnect inputs one by one until you find the bad one.and change it.
Aug 27, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
355 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
