Question about Verona FSGE648FS Dual Fuel (Electric and Gas) Kitchen Range
Oven Door won't close all the way
Mikey -
The small oven door on my verona range (FSGE648FS) dual fuel range does not close all the way - we stored a pot in the oven & handle held the door ajar just a bit - did not notice at first - but this seemed to "teach" the door to only close that far. No apparent adjustment (that I can figure) on the door & no response from Verona.
I also need help w/ main oven - convection element does not heat - don't know it I need switch or new element - can I diagnose w/out taking the oven apart?
Thanks. M8954
  • onthecorner Oct 01, 2008
    The small oven door always had special needs from day one but now it hangs open 3/4" all the time! Anyone have a solution or thoughts?
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Apr 29, 2013 | Verona VEFSGE365DAW 36" Double Oven Dual...
Door seal small oven needs replaceing
many thanks, sorted. ordered at local supplier. regrards tb.
Dec 08, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
The oven door on my Whirlpool oven won't stay closed
Need new hinges. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Sep 01, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Fan oven door, cooker surround and hob become burining hot when using fan oven
Sounds like a problem to me. Check your oven door gasket to make sure it's intact and also that the oven door is closing completely when this overheating occurs. Although some heat will rise, it shouldn't become "burning hot".
Mar 09, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Verona FSGE648FS Dual Fuel (Electric and Gas) Kitchen Range Logo
88 people viewed this question
Top Verona Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Verona Kitchen Range Expert? Answer questions, earn points and help others
