Question about Cuisinart DGB-600 Coffee Maker
Stuck The grinder basket has been difficult to remove for some time.  I finally order a new one, but alas, the same problem has occurred--only now I can't get the bottom part of the grinder out at all.  Do I have to abandon what  has been our favorite of all time coffee pot?  We've had this appliance for almost four years, and the problem didn't start until about a year ago.  I wash the grinder and brew baskets after every use. Please reply to carolyn508@comcast.net
  • 4 more comments
  • Anonymous Sep 26, 2008
    For what it's worth, my grinder has developed the same issue.
  • JMRGF Oct 02, 2008
    I have the same problem, any solutions?
  • meomyo Oct 16, 2008
    my grinder is stuck.. can't get out
    thanks
    mine is stuck also .. any advise greatly appreciated.. thank you
  • superbsaint Feb 17, 2009
    i have the same problem also!....have used this unit approximately 8 times and the last two times the grinder portion has become "lodged" in and will not come out.....the first time i just kept wiggling it around till it finally broke loose but this time it won't come out for anything?....Really Frustrating!!....otherwise I would consider this the perfect machine....but it isn't any good if you can't use it??
  • wmcc Mar 14, 2009
    I was able to remove the grinder a few times, but now it got stuck. Using a hammer to brute force it as a solution is too high a risk to cause damage, especially if it keeps on happening. For now I just use a separate grinder until the root cause is identified and fixed.
  • 515 Answers
I had never heard this before, i will check this when i am on work again to see if i can give you a solution.
Best regards
/Mirran
Posted on Sep 25, 2008
I have a Cuisinart Grind and Brew coffee maker that is about a year old. The lower half of the grinder gets stuck. It used to be occasionally but is happening more frequently. It is very hard to get it...
These are notorious for this problem. It is cause by the coffee grinder portion wearing out and sticking. After a while the grinder will fuse to the basket. It is cause by the spinning of the grinder and wear to the grinder shaft or coffee grounds getting into the shaft and causing wear. Either wan the only fix is a new basket.Send Cuisinart an email to complain and they may give you a new one free. I went through 3 before I gave up on the grind and brew model.
Feb 06, 2011 | Cuisinart DCC-1200 Coffee Maker
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I CANNOT REMOVE THE GRIND BASKET TO CLEAN IT.
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
a little cooking oil on the shaft before you insert the grinder will help, spray on pam works well and is easy to do...
Jul 01, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart coffee maker grinder stuck in machine. Can't remove to wash
Same problem and I'm the husband that always got it unstuck...... until this morning. I read somewhere that putting the whole machine in the freezer will work. I did and the grinder just lifted out without any pressure at all! My wife was laughing at me when I was looking on line for a solution but she just smiled when it was removed.......
Aug 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
Put the whole brewer in your refrigerator freezer for 2 hours. The coffee basket then will come off. Take the entire brewer unit to your shower and rinse it thoroughly. Now look at the basket and where it goes on the brewer. You will see a little spindle and 2 sets of helical gears. Spread white lithium lube on the spindle and the gears. It won't get in your coffee because it's nowhere near the water flow. This should solve the stuck basket problem.
Dec 29, 2007 | Cuisinart Grind and Brew 10 Cup Coffee...
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-600 Coffee Maker Logo
281 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
