Vistron 32 i have a vistron 32" and the problem is after about 15 minutes of the television being switched on, the left half of the screen turns a tint of blue/green and stays like that. if i turn the television off and back on again, the screen returns to normal but not for long. i cant find a contact address for the company i bought it from and even though i bought it through Ebuyer, they are not much help. looks like i have got stung. however, the television still does not work and i wonder if anyone had any ideas as to what is wrong with it and whether imbest either slinging it in the bin or getting it repaired?
  • m_roberts Sep 23, 2008
    yes mediarich!! you was correct! i had checked for speakers previously and there was none. but i have a wireless transmitter that sends the TV reception to a portable TV in the kitchen. i unplugged that. and hey presto!
    thank you very much you have been a great help and provided a very quick response
    Scholar:
  • 188 Answers
I hope this is as simple as making sure there are no speakers or other devices with magnets or tranformers in them next to the TV. When the TV is first turned on there is a demagnetizing coil (degause coil) that comes on and demagnetises the picture tube. If there is a magnet by the TV it will cause the problem you are seeing.
Posted on Sep 23, 2008
Samsung LNT4661 FX/XAA when you turn tv on picture is ok after a few minutes bottom half of screen puts red tint horizontaly across screen it will sometimes go away after 15 or 20 min. What is the...
Hi there are two things that could be causing these this. Either your t-con board is bad or your screen is bad. Since screens are so expensive I would replace the T-con board to see if that fixes the problem.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
My Vizio has a shaded are on the left portion of the screen that flickers on and off and sometimes on the whole panel. It has a brownish tint to it. What is causing this? I have had it a year and a half.
It's lasted that long! Could the brownish tint be mistaken for pink? Sounds like the lamp(s) in the backlight panel are starting to go. Usually an expensive repair. Get an estimate but may be better to use the repair money on a better brand set. Vizio's have a very high failure rate.
Apr 23, 2010 | Vizio GV42L 42 in. LCD Television
Blue tint left side of tv
sounds like you need a new light engine. Sony can probably get you one at no cost if make enough noise, they are aware of problems with their light engines. good luck
Apr 25, 2009 | Sony KDF-50E2000 50" HDTV
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Oct 22, 2007 | Nintendo DS Lite Console
Purple tint
Do not put a colour television near a strong magnetic field. I have confirmed from several experts that this has the undesired effect of causing loss of colour
Jan 10, 2006 | Panasonic CT-27SF26 27" TV
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
